Zte gx670 need help salam plz my phone zte GX 670 is dead i try with all filles in suport but not work COM6 [VCP1] selected module v3.73 Device: ZTE-X670_16mb Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware ZTE-X670_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X670_V1_Z2_ FRES_BFFA100_En_Fr_Es.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:EC03:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: E488D47E rom info ver: 07 sw version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN project-id: X670_V1_OG_Z2_FRES_DFFA111, 09457FC0 code offset: 00000000 ffs offset/size [02]: 01000000/01000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 01000000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.E488D47E.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X670_V1_Z2_FRES_ BFFA100.BIN_FB00A964].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.E488D47E._ZTEMT25_ 07A_PCB01_GPRS_MT6225_S00.X670_V1_Z2_FRES_BFFA100. BIN_FB00A964_.rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.E4 88D47E.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X670_V1_Z2_FRES_ BFFA100.BIN_FB00A964].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.E4 88D47E._ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X670_V1_ Z2_FRES_BFFA100.BIN_FB00A964_.rpl ==================== warning: unknown firmware: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X670_V1_Z2_FRES_ BFFA100.BIN_FB00A964 Unknown firmware found (v.3.73, database date: 19.01.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X670_V1_Z2_FRES_ BFFA100.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? Area: Firmware flash: EC227E22632260:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: EC227E22632260:18E59F00000000 Finalization Done Finished, time used: 10 min 31 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
plz i m waiting the help |
Hi, What was the problem with phone when you have got it ? |
