04-03-2015, 09:47 | #1 (permalink) |
Product Supporter Join Date: Mar 2008 Location: Thailand Age: 46
Member: 716581 Status: Offline Thanks Meter: 767 | ZTE MT6572 PROBLEM After Flash Fatory File. Code: Card found: S/N 1323:0128 Chinese Miracle II [MTK module] v 1.16 Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040504A2649A126D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040504A2649A126D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : ZTE ProdName : P172R10 ProdModel : ZTE V816W Device : P172R10 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : DAT_TH_QB15DX_P172R10V1.0.3 [Read Ok] : preloader_ztenj72_we_72_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / ztenj72_we_72_kk / EMMC FW Size : 988 MiB Scatter saved to : C:\Users\nOng\Desktop\MT6572__ZTE__ZTE V816W__P172R10__4.4.2__DAT_TH_QB15DX_P172R10V1.0.3\ All done! Done! Elapsed: 00:04:38 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : ztenj72_we_72_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.16 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040504A2649A126D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040504A2649A126D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : ztenj72_we_72_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled SecCfg Passed , 1799 BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BMT remark not need. Will skip BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:14 BL : Clear old BL Data BL : Clear old BL Data Ok Sending Preloader ... Use : preloader_ztenj72_we_72_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:09 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:56 Update RomInfo done Done! Elapsed: 00:03:42 Reconnect Power/Cable! |
04-03-2015, 09:58 | #2 (permalink) |
Member: 716581 Status: Offline Thanks Meter: 767 | Full Flash Fail @ 95% Code: Operation : Flash [ v1.16 ] ======= Flash Files set for flashing : [ MCU ] : MT6572_ZTE_V816W__DAT_TH_QB15DX_P172R10V1.0.3__Android_4.4.2__20150204_100109.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040504A2649A126D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040504A2649A126D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ISPFF ID : 6572 TARGET ID : 6572 Flash pre-erase disabled Write Flash now ... [ MCU ] : MT6572_ZTE_V816W__DAT_TH_QB15DX_P172R10V1.0.3__Android_4.4.2__20150204_100109.bin Init Ok , Sending blocks ... Write failed :( Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:06:47 Reconnect Power/Cable! |
04-03-2015, 09:59 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Explain - your read file from phone, which stuck on logo, and after write it back as factory firmware? Right? Fail after 9x% - change nothing. eMMC can block some bad block and e.t.c. to avoid data damage. After phone will work in any way. Sure, if DUMP is Ok. |
04-03-2015, 10:01 | #4 (permalink) |
Member: 716581 Status: Offline Thanks Meter: 767 | This is new phone and good condition and i read flash form phone and test write back. The drum flash sucess with volcano and phone working fine |
04-03-2015, 10:03 | #5 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | After write flash as dump back - what phone condition now? And what will be result , if you flash fw via SPFT? I still improving flash engine. |
04-03-2015, 10:10 | #7 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
95% - it not write near 150 MB of space, which was user area. If phone new and not stuffed up to 99% full memory with user content - this change completely nothing. After flashing - you said it stuck - how long you check it? On slow eMMC's it can take up to 5-7 minutes. Android build new user and cache area with given data by CM2 and it can take time. | |
04-03-2015, 10:19 | #9 (permalink) |
Member: 716581 Status: Offline Thanks Meter: 767 | i try with SPFT Upgrade firmware same phone stuck on logo. i try full flash and fail @ 95% phone and power on but have some error after that i try flash with SPFT Download only. the phone working file. |
04-03-2015, 13:49 | #13 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Aha. Thanks for info. I will add "download only" like method in CM2MTK too in some near time. If you face such problem one more time with other some phone - let me know. |
