Old 04-26-2018, 16:59   #1 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 594
ZTE N9560 unsupported SecureType!
Hope taht Jaydi can add it soon to CM2QLM module...
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Read Flash [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 435 [MSM8940]
ID_BLOCK_S : 85F58AEB
ID_BLOCK_E : 00040000
ID_BLOCK_L : 22B43A996B81EA8FA0AF934F229C44C1
ID_BLOCK_L : 17DE023BC25DCFF4392FC390EE62F92F
Use CM2 Internal Loader
ERROR : Prepare target failed! Unsupported SecureType!
INFO : Send log and report.log to support! Include device info also!
Reconnect Power/Cable!
Old 04-26-2018, 17:21   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,597
Link : here
Unpack files to boot folder. Restart software.
Use.
request : upload report log, it will be generated on firmware read try.
Old 04-26-2018, 17:37   #3 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 594
Not working yet, here log:
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Loader Sent! Initializing ...
ERROR : FH Configuration failed!
HINT : Remove battery, cable. Check cable and connection. Repeat operation!
Old 04-26-2018, 17:40   #4 (permalink)
JayDi's Avatar
Member: 462970
Device alive and work?
Old 04-26-2018, 17:45   #5 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 594
yep it's alive and working!
I also changed cable/usb port and same error.
Old 05-11-2018, 21:13   #6 (permalink)
Member: 322417
Thanks Meter: 903
Wich Button combination u use ?
I use Vol UP + Down and its recognizes as
Old 05-12-2018, 16:46   #7 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 594
enable usb debbuging and the magic command is:
"adb reboot edl" ...without quotes
Note: if you manage to enter fastboot also should work "fastboot reboot-edl"...I guess
Old 05-12-2018, 18:19   #8 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 594
also the adb command should work in FTM mode, just try it
Page generated in 0.25281 seconds with 7 queries
