05-10-2008, 15:06 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: world
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | blue tooth 2.0 bad software my blue tooth 2.0 bad software. after repair eprom and write firmware set on but no disply. here is eprom file name--- MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__Cect-LV918_eeprom_03.B0E.bin and here is fimware name---- MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__16m_Ru_Fr_En_Th_Vn_Ar _w_eeprom.B0M.bin here is detail information log befor flashing COM5 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:B703:000A boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1_17_ P1HXM25BC30_ST_CN.BIN ver. sw2: M608_V_1.17_P1HxM25BC30_ST_CN, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ...................... detect standard fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ...................... detect standard fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 143 sec Remove/Install battery now ! pls help me |
05-11-2008, 21:45 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you used wrong file for flashing. your firmware version is MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1_17_ P1HXM25BC30_ST_CN but you used MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN |
05-12-2008, 08:27 | #4 (permalink) | |
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | Quote:
pls tell me similer file name. | |
05-12-2008, 08:39 | #5 (permalink) |
Freak Poster Join Date: Apr 2006 Location: india
Member: 254397 Status: Offline Thanks Meter: 224 | i have 7 peace bluetooth 2.0 i try flash with also file form support area 1 by 1 but some phone going 'white screen' or some 'bad software' after flashing. we know infinity team is great but this modle not proper solution have infinity team. please update this modle. ..::RICKY RAYYA::.. |
05-12-2008, 10:07 | #6 (permalink) |
Banned Join Date: May 2006
Member: 270936 Status: Offline Thanks Meter: 33 | yes what u said is rite, and am also holding the same bad software for the last four months in hand after trying all the flashes in the support site.still waiting for the best result. |
Blue tooth 2.0 bad software after format | nilan | SpiderMan | 3 | 05-15-2008 08:04 |
blue tooth mobile " bad software " | IBMOBILES | Chinese Cocktail | 9 | 11-04-2007 11:34 |
Chines phone Blue Tooth 2.0 LV918 | now_mobiles | Infinity-Box | 5 | 11-02-2007 16:24 |
Chinese Blue Tooth 2.0 Not Connecting | sahil2000ind | Infinity-Box | 19 | 10-23-2007 12:30 |
