12-10-2018, 11:11 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Online Thanks Meter: 2,769 | Zte q5-t firmware needed Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 054DA8A5 ID_BLOCK_L : 22C2B846F17D6A654237D9C60158D8F0 ID_BLOCK_L : 047FC1686DF466EFE2CD867F75B8B695 Use CM2 Internal Loader FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 054DA8A5 ID_BLOCK_L : 22C2B846F17D6A654237D9C60158D8F0 ID_BLOCK_L : 047FC1686DF466EFE2CD867F75B8B695 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : ZTE ProdName : CU_P816T32 ProdModel : ZTE Q5-T Device : CU_P816T32 AndroidVer: 6.0.1 Manufact. : ZTE SysPatch : KTU84P DevComTime: 12/7/2015 4:06:45 AM QLMxCPU : MSM8916 USERData : ENCRYPTED GCSec : EMPTY Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 054DA8A5 ID_BLOCK_L : 22C2B846F17D6A654237D9C60158D8F0 ID_BLOCK_L : 047FC1686DF466EFE2CD867F75B8B695 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Repair block Ok! Repair block Ok! Forced Fix Failed! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
12-17-2018, 22:46 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
12-17-2018, 23:57 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | If you have brick, you can restore according to THIS instruction, or even easier - using those files from that page, and CM2QLM module - Memory tool, etc. p.s. ZTE Q5-T = ZTE Blade S6 p.s.2 Use Google translate on that page ... b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
