Zte q505t firmware needed AFTER USE CM2 QLM TO WIPE USERDATA/CACHE PHONE STUCK ON LOGO Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 011F1D57 ID_BLOCK_I : 008050E1 ID_BLOCK_L : 6C94CE08A733382B14498B94532EA6A6 ID_BLOCK_L : FA8937969B0AB431D42374ADA74E5863 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : ZTE ProdName : P826T20 ProdModel : ZTE Q505T Device : P826T20 AndroidVer: 4.3 Manufact. : ZTE SysPatch : JLS36C DevComTime: 4/28/2014 7:29:38 AM QLMxCPU : MSM8226 USERData : NORMAL GCSec : NORMAL Done! Elapsed: 00:00:25 Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 011F1D57 ID_BLOCK_I : 008050E1 ID_BLOCK_L : 6C94CE08A733382B14498B94532EA6A6 ID_BLOCK_L : FA8937969B0AB431D42374ADA74E5863 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
phone don't go to ADB, EDL again. please help HOW TO SOLVE? no backup..... |
Device too old. EMMC can be dead. Make EMMC RO test. Some files, if ZTE provide OTA updates - you can extract from OTA.zip and write with memory tool. Or wait someone, who can read FW. |
link rom : 4.3.1 Q505TV1.0.0B05 http://devicedownload.zte.com.cn/sup...10609431417.7z how to update ÖÐÐËQ505TÇ¿ÖÆÉý¼¶Ë¢»ú½Ì³Ì(¹Ù·½¾Èש)_ÖÐÐËË¢»ú½Ì³Ì_Ö ÐÐËË¢»úÍø source ÖÐÐËQ505TË¢»ú°ü_ÖÐÐËQ505T ROMÏÂÔØ_ÖÐÐËQ505T¹Ù·½¹Ì¼þ_ÖÐÐËË¢»úÍø use translation |
extract boot chain : sbl,tz,boot,recovery,rpm from ota write with memory tool. If all files write correctly done - then you should get recovery. |
Operation : Memory Tool Init [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 011F1D57 ID_BLOCK_L : 6C94CE08A733382B14498B94532EA6A6 ID_BLOCK_L : FA8937969B0AB431D42374ADA74E5863 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Set default path : C:\InfinityBox\CM2QLM\phdata\ Ready! Operation Write Memory [ v1.16 ] Write selected partitions [5] [0] Write partition : SBL1 Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\sbl1. mbn Write partition Ok! [1] Write partition : RPM Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\rpm.m bn Write partition Ok! [2] Write partition : BOOT Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\boot. img Write partition Ok! [3] Write partition : TZ Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\tz.mb n Write partition Ok! [4] Write partition : RECOVERY Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\recov ery\recovery-from-boot.p Write partition Ok! Operation finished! |
Phone reboot and enter edl mode. Not display atall again |
recovery-from-boot NOT RECOVERY ! Did you try make eMMC test? Then try other thing : Read any partition. sbl1for example. Erase that partition. Reboot device. Check that partition state in memory tool again. It must be empty. |
Card found : A6xxxxx5 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Memory Tool Init [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 011F1D57 ID_BLOCK_L : 6C94CE08A733382B14498B94532EA6A6 ID_BLOCK_L : FA8937969B0AB431D42374ADA74E5863 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Set default path : C:\InfinityBox\CM2QLM\phdata\ Ready! Operation : Test Memory [ v1.16 ] Preparing memory test ... Step #1 passed Step #2 passed Memory is Ok! Clean Ok! Operation finished! Nothing to do! Select partition(s) first! Operation : Read Memory [ v1.16 ] Reading selected partitions [1] [0] Read partition : SBL1 Saved to : C:\InfinityBox\CM2QLM\phdata\SBL1.bin Operation finished! Operation : Erase Memory [ v1.16 ] Erase selected partitions [1] [0] Erase partition : SBL1 Erase partition Ok! Operation finished! Close MemoryTool session Done! Elapsed: 00:03:12 Reconnect Power/Cable! Operation : Memory Tool Init [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 011F1D57 ID_BLOCK_L : 6C94CE08A733382B14498B94532EA6A6 ID_BLOCK_L : FA8937969B0AB431D42374ADA74E5863 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Set default path : C:\InfinityBox\CM2QLM\phdata\ Ready! Operation Write Memory [ v1.16 ] Write selected partitions [5] [0] Write partition : SBL1 Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\sbl1. mbn Write partition Ok! [1] Write partition : RPM Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\rpm.m bn Write partition Ok! [2] Write partition : BOOT Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\boot. img Write partition Ok! [3] Write partition : TZ Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\tz.mb n Write partition Ok! [4] Write partition : RECOVERY Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\facto ry.img Write partition Ok! Operation finished! Close MemoryTool session Done! Elapsed: 00:04:29 Reconnect Power/Cable! |
i don't know maybe i doing something wrong but here is extracted file http://i64.tinypic.com/30k3pfs.jpg |
Set boot partition to drive0 in memory tool After write boot files |
flash sdi also. At same part name. flash NON-HLOS.bin as modem image. emmc_appsboot - as aboot and again rest parts at same names. Recovey wrong in both cases. Until you not flash correct recovery - you will not get it working. |
