Old 03-12-2018, 01:08   #1 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,877
Zte q505t firmware needed
AFTER USE CM2 QLM TO WIPE USERDATA/CACHE PHONE STUCK ON LOGO
Operation : Identify [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 400 [MSM8x26/28]
ID_BLOCK_S : 011F1D57
ID_BLOCK_I : 008050E1
ID_BLOCK_L : 6C94CE08A733382B14498B94532EA6A6
ID_BLOCK_L : FA8937969B0AB431D42374ADA74E5863
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1
ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000
Boot Ok!
Brand : ZTE
ProdName : P826T20
ProdModel : ZTE Q505T
Device : P826T20
AndroidVer: 4.3
Manufact. : ZTE
SysPatch : JLS36C
DevComTime: 4/28/2014 7:29:38 AM
QLMxCPU : MSM8226
USERData : NORMAL
GCSec : NORMAL
Done!
Elapsed: 00:00:25
Operation : Reset Settings [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Done!
Elapsed: 00:00:21
Reconnect Power/Cable!
Old 03-12-2018, 01:12   #2 (permalink)
Member: 1677653
Thanks Meter: 1,877
phone don't go to ADB, EDL again.
please help HOW TO SOLVE?
no backup.....
Old 03-12-2018, 06:05   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,596
Device too old.
EMMC can be dead.
Make EMMC RO test.
Some files, if ZTE provide OTA updates - you can extract from OTA.zip and write with memory tool.
Or wait someone, who can read FW.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-12-2018, 06:18   #4 (permalink)
Member: 2671513
Thanks Meter: 106
link rom : 4.3.1 Q505TV1.0.0B05
http://devicedownload.zte.com.cn/sup...10609431417.7z
how to update
中兴Q505T强制升级刷机教程(官方救砖)_中兴刷机教程_ 行怂⒒
source
中兴Q505T刷机包_中兴Q505T ROM下载_中兴Q505T官方固件_中兴刷机网
use translation
The Following User Says Thank You to dadarko For This Useful Post:
Old 03-12-2018, 15:49   #5 (permalink)
Member: 1677653
Thanks Meter: 1,877
Phone didn't enter recovery mode... I think I will need backup firmware
Old 03-12-2018, 15:56   #6 (permalink)
JayDi's Avatar
Member: 462970
extract boot chain :
sbl,tz,boot,recovery,rpm from ota
If all files write correctly done - then you should get recovery.
Old 03-12-2018, 16:32   #7 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,438
hold all kye for force shutdown and conncet edl cable and hold switch then realse
The Following User Says Thank You to sneha For This Useful Post:
Old 03-12-2018, 16:44   #8 (permalink)
Member: 1677653
Thanks Meter: 1,877
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Memory Tool Init [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 400 [MSM8x26/28]
Boot Ok!
Set default path : C:\InfinityBox\CM2QLM\phdata\
Ready!
Operation Write Memory [ v1.16 ]
Write selected partitions [5]
[0] Write partition : SBL1
Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\sbl1. mbn
Write partition Ok!
[1] Write partition : RPM
Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\rpm.m bn
Write partition Ok!
[2] Write partition : BOOT
Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\boot. img
Write partition Ok!
[3] Write partition : TZ
Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\tz.mb n
Write partition Ok!
[4] Write partition : RECOVERY
Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\recov ery\recovery-from-boot.p
Write partition Ok!
Operation finished!
Old 03-12-2018, 16:46   #9 (permalink)
Member: 1677653
Thanks Meter: 1,877
Phone reboot and enter edl mode. Not display atall again
Old 03-12-2018, 17:13   #10 (permalink)
JayDi's Avatar
Member: 462970
recovery-from-boot NOT RECOVERY !
Did you try make eMMC test?
Then try other thing :
Read any partition. sbl1for example.
Erase that partition.
Reboot device.
Check that partition state in memory tool again.
It must be empty.
Old 03-12-2018, 23:15   #11 (permalink)
Member: 1677653
Thanks Meter: 1,877
Card found : A6xxxxx5 , v0136
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Ready!
Operation : Test Memory [ v1.16 ]
Preparing memory test ...
Step #1 passed
Step #2 passed
Memory is Ok!
Clean Ok!
Operation finished!
Nothing to do! Select partition(s) first!
Operation : Read Memory [ v1.16 ]
Reading selected partitions [1]
[0] Read partition : SBL1
Saved to : C:\InfinityBox\CM2QLM\phdata\SBL1.bin
Operation finished!
Operation : Erase Memory [ v1.16 ]
Erase selected partitions [1]
[0] Erase partition : SBL1
Erase partition Ok!
Operation finished!
Close MemoryTool session
Done!
Elapsed: 00:03:12
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Ready!
Write partition Ok!
Write partition Ok!
Write partition Ok!
Write partition Ok!
Write from : C:\Users\Yuslam Unique\Downloads\2015010609431417\Q505T SD卡升级包(中国移动)272890B1401Q505TV1.0.0B04\update\facto ry.img
Write partition Ok!
Operation finished!
Done!
Elapsed: 00:04:29
Old 03-12-2018, 23:20   #12 (permalink)
Member: 1677653
Thanks Meter: 1,877
i don't know maybe i doing something wrong but here is extracted file
Old 03-13-2018, 02:15   #13 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,291
Set boot partition to drive0 in memory tool After write boot files
The Following User Says Thank You to rebainoor For This Useful Post:
Old 03-13-2018, 19:27   #14 (permalink)
JayDi's Avatar
Member: 462970
flash sdi also. At same part name.
flash NON-HLOS.bin as modem image.
emmc_appsboot - as aboot
and again rest parts at same names.
Recovey wrong in both cases. Until you not flash correct recovery - you will not get it working.
Page generated in 0.38259 seconds with 7 queries
