05-19-2011, 22:25 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | zte r225 at&t in the sticker model is hw:g9kb zte in the menu information of phone model is r225 comes from at&t i try to unlock by standart method result : phone not power on and nvram_sec_xxxx_xxxx legend apear on screen after read some in forum i read some thread regarding this phone, flashed by flash from support i flash the phone with flas from support result: still having power on problems with legend nvram:sec_xxx_Xxx the last try erase whole flash chip, flash with same flash file from support result: phone power on well but locked unlock using smart fast method result phone unlocked / repaired well * using 800/1900 band thanks infinity for great tool for chinisse phones |
The Following User Says Thank You to rogerboogie For This Useful Post: |
12-13-2011, 18:30 | #4 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
maybe your phone's IMEI is blacklisted? maybe your country uses unsupported frequency? can you see networks if you do "search" via menu? can you call 112 (sos number)? | |
11-23-2012, 13:06 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News - 22-11-2012 - Online Service updated 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell. It's just an example for Alcatel, if you have another model you must select your model ! RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts |
r225 | bonzobob999 | VLSI, Conexant, Skyworks and Old Models | 5 | 09-15-2008 16:44 |
Flash for r225 need | Yevgeny | VLSI, Conexant, Skyworks and Old Models | 2 | 03-30-2006 11:50 |
flash samsung R225 | Quang Thao | VLSI, Conexant, Skyworks and Old Models | 5 | 08-02-2005 14:00 |
Log For At&t T68 Does Not Work! | lorenzo | Phone Unlocking Codes & Maps | 2 | 07-19-2002 02:02 |
r225 dump unlocker | s4sajii | VLSI, Conexant, Skyworks and Old Models | 7 | 07-10-2002 15:34 |
