03-19-2013, 08:38 | #1 (permalink) |
Crazy Poster Join Date: Jan 2011
Member: 1496350 Status: Offline Sonork: 100-1626476 Thanks Meter: 2 | ZTE s1602 flashing fail COM132 [QCUSB_COM132_1] selected module v1.92 Device: ZTE-S1602 operation: Read information Phone should be Switched ON ! connecting... --------------------------------------------------------- HARDWARE : SSTL_S16 COMPILE : Mar 07 2011 (14:14:00) REALEASE : Apr 24 2009 (24:00:00) SW Version : --------------------------------------------------------- ESN(hex) : 802F0FA3 ESN(hex) : Phonce code : Finished, time used: 13 sec file selected: J:\INFINITY\ZTE-S1602\ZTE-S1602_SSTL_S1602_RBTL40NV1.0.1B01_16Mb.bin ==== [3/19/2013 12:41:20 PM] ==== COM132 [QCUSB_COM132_1] selected module v1.92 Device: ZTE-S1602 operation: Write Flash Phone should be Switched ON ! connecting... ESN(hex) : 802F0FA3 Password accepted.. downloading mode... waiting to connect... execution protocol... flashchip : INTEL 128 L18 ADMuxd ƒ erasing... Start flashing... =======W.A.R.N.I.N.G======= DO NOT REMOVE THE PHONE..!! ------------------------------------------------------------- flashing failed... Finished, time used: 2 min 59 sec read Before flashing Any Zte-phones a)You must use Read information Button to see which version of phones you have if Your phone is Between October2010 to MArch2011 .Then your phone is 16 mb must select 16 mb flash file and flash phone. b)If your phone is From April to June 2011 You must be carefull to flash this phone to unknown chiness version you do this at your own risk and void Warranty of phones as logo and other part of firmware is changed c)You must not do any other operation while flashing phones d)Phone is auto powered so avoid using battery to power on phones use Good qwality Usb Cabel. e)Must remeber if your PC is hang or software get closed due to some unavoidabel Reasons phone will be dead. f)Once phone Dead you need Flash programer to revive phones our tool not support Dead phones g)If you are ok with all above points then you can try flash operation . h)Purpose of flashing is to Repair phones other purpose you do at your own Risk this is march 2011 flash file is 16mb why flashing fail please help me any solution any anthor tool by flashing |
The Following User Says Thank You to srinivas.sai For This Useful Post: |
03-21-2013, 09:10 | #4 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Just Imagine Age: 42
Member: 1191481 Status: Offline Sonork: 1592603 Thanks Meter: 1,373 | Quote:
Flashing Fail Some time Due To Port Hang Or Any Other Application Working Always Avoid Work During Flashing Wbr <<<Megatron>>> | |
