07-17-2010, 10:27 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: westbengal(katwa)
Member: 1175892 Status: Offline Thanks Meter: 61 | Zte s212 unlock dead pls help............. module v3.49 Device: ZTE-S212 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7040:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.A5E9D BDC.[M7026DJWT_UNINOR_PCB01_GPRS_MT6223_S00.E-IN-UNINOR-P109A12V1_0_1B01.BIN_6D57F220].rpl rom info detection finished device-id: A5E9DBDC rom info ver: 05 sw version: M7026DJWT_UNINOR_PCB01_GPRS_MT6223_S00.E-IN-UNINOR-P109A12V1_0_1B01.BIN project-id: E-IN-UNINOR-P109A12V1.0.1B01, 20F2576D code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00700000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-S212_M7026DJWT_UNINOR_PCB01_GPRS_MT6223_S00.E-IN-UNINOR-P109A12V1_0_1B01__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-S212_M7026DJWT_UNINOR_PCB01_GPRS_MT6223_S00.E-IN-UNINOR-P109A12V1_0_1B01__ffs_20100717-112739.B0E.bin flash: EC257E25062501:2BEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ............... required data found flash: EC257E25062501:2BEA0000000000 flash: EC257E25062501:2BEA0000000000 Write: area 1 (pass 1) required data found flash: EC257E25062501:2BEA0000000000 flash: EC257E25062501:2BEA0000000000 Write: area 1 (pass 2) ................. area 1 patch applied Ok detecting parameters to apply patch area 2... ................................ error: area 2 can not apply patch Special operation Done ====> Write ... flash: EC257E25062501:2BEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-S212_M7026DJWT_UNINOR_PCB01_GPRS_MT6223_S00.E-IN-UNINOR-P109A12V1_0_1B01__system_log_A5E9DBDC_6D57F220_201 00717-112905.B0X.bin Finished, time used: 4 min 10 sec Remove/Install battery now |
The Following 2 Users Say Thank You to RABIULSK For This Useful Post: |
07-17-2010, 11:58 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | This phone can not be dead after unlock. I think your battery is empty, so, please, check battery voltage first, then we will see what to do. |
07-19-2010, 16:53 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | @gsmdevice it's not true, you are wrong ! @RABIULSK try to S212 flash phone with different files from support area, it may be some kind of firmware <-> hardware incompatibility. Also, please remember, that we do not upload bad files in support area, so, please, do not ask us "upload good file" - all files in support area already very good. |
07-22-2010, 16:13 | #8 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 420862 Status: Offline Thanks Meter: 51 | Yes i too got this problem when i try to unlock Zte S212 uninor handset it was dead , also i restore my backup but no use . Then i got another handset read its bin file from other tool and write to my phone now all is ok but not unlocked . RapidShare: 1-CLICK Web hosting - Easy Filehosting u can get file from above link but 10 times only as it is not collectors acc . Pl excuse for that . regards rockgsm |
The Following User Says Thank You to rockgsm For This Useful Post: |
07-22-2010, 18:17 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | @rockgsm We need to get full flash backup file that was read with Infinity-Box software. It's very important to read flash from this phone with Infinity-Box software. please, do it and upload again. Thank you ! Also, did you tried to unlock this phone with "smart fast" unlock method ? |
07-23-2010, 05:24 | #10 (permalink) | |
Member: 1175892 Status: Offline Thanks Meter: 61 | Quote:
07-30-2010, 20:03 | #14 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | 1. run software 2. go to software "Service" page 3. do not change any settings, software select optimal settings for each model by default ! 4. press "sp-unlock" button and follow the instruction given by software in log window |
07-30-2010, 20:14 | #15 (permalink) |
Insane Poster Join Date: Sep 2006 Location: rest of world
Member: 354903 Status: Offline Thanks Meter: 10 | succsesfull unlock with infinity. 100% s212,r220.. just click on smart method unlock. be sure about full charg battery,good cable, if ur cable is fulty u may in prob... |
The Following User Says Thank You to salim_sk567 For This Useful Post: |
