10-24-2010, 12:55 | #1 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1398200 Status: Offline Thanks Meter: 1 | Problem with find pins in vertu77 (Heijingang V77) VERTU, V77 - Allymobile whole sale supplier I try in many many possibilities (cable l12c) activation tries and power cycles and nothing find . Mayby this phone have other bord ? When i get manual search china miracle not see it. What i doing wrong ? |
10-24-2010, 22:47 | #4 (permalink) |
Member: 1398200 Status: Offline Thanks Meter: 1 | Mayby is not mt62.. phone . When i get pin rx 1 tx 2 phone is turn on but china miracle tell my COM11 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read firmware ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 4 sec Remove/Install battery now ! |
10-25-2010, 19:27 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is mtk family |
10-26-2010, 00:21 | #8 (permalink) |
Member: 1398200 Status: Offline Thanks Meter: 1 | I did`t find pin....automatic. I try many time with many settings. When i get manual pin rx 1 tx 2-4 china miracle have this masage Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! when i get tx 5-6 chinamiracle not find nothing and phone show my cable as headphones . I did`t have this problem in other phone |
10-27-2010, 12:00 | #11 (permalink) |
Member: 1398200 Status: Offline Thanks Meter: 1 | I was open phone and find field rx tx and power but i dont now which cables use to connect with this ... I need to solder? Ps i have 4 other phone with thit same problem no detect pins |
10-27-2010, 20:26 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! unfortuntely if pinout is presented as test points- you must solder. here is example of how to make own cable: http://forum.gsmhosting.com/vbb/f296...-cable-386780/ |
10-28-2010, 16:29 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! is it with Rj45 connector? same as on my picture? If yes- then you must count pins and see what colur they are. you need pins 2,3,8 please look to my post above, there is explaned with pictures |
10-28-2010, 18:37 | #15 (permalink) |
Member: 1398200 Status: Offline Thanks Meter: 1 | No hi have com connection for infinity box plus .When i make photo I will send to you . Ps if i will connect cabel directly to rx tx not will by problems with find pinout of phone and read flesh file ? ( i need infinty plus or only normal box with china miracle ) |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
