09-25-2010, 16:37 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Denmark Age: 41
Member: 268415 Status: Offline Thanks Meter: 57 | ZTE Sage dead after unlock here is the flash log. Code: COM7 [VCP0] selected module v3.61 Device: ZTE-Sage Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671_V1_Z1_ES_DFFA105__fullflash_20100810-220456.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671_V1_Z1_ES_DFFA105__ffs_20100810-221724.B0E.bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:8203:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.60CFDD31.[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671_V1_Z1_ES_DFFA105.BIN_24447341].rpl rom info detection finished device-id: 60CFDD31 rom info ver: 07 sw version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671_V1_Z1_ES_DFFA105.BIN project-id: X671_V1_Z1_ES_DFFA105, 41734424 code offset: 00000000 ffs offset/size [02]: 01C00000/00400000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 01C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-Sage_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671_V1_Z1_ES_DFFA105__system_log_60CFDD31_24447341_20100925-203029.B0X.bin Area: Firmware flash: EC227E22632260:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: EC227E22632260:18E59F00000000 Write: Eeprom/ffs usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: EC227E22632260:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-Sage_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671_V1_Z1_ES_DFFA105__system_log_60CFDD31_24447341_20100925-203442.B0X.bin Finished, time used: 4 min 49 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
09-25-2010, 22:10 | #3 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 407 | Quote:
Action: write flash | |
09-26-2010, 11:07 | #5 (permalink) |
Member: 268415 Status: Offline Thanks Meter: 57 | COM7 [VCP0] selected module v3.61 Device: ZTE-Sage Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:8203:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.60CFD D31.[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671_V1_Z 1_ES_DFFA105.BIN_24447341].rpl rom info detection finished device-id: 60CFDD31 rom info ver: 07 sw version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671_V1_Z 1_ES_DFFA105.BIN project-id: X671_V1_Z1_ES_DFFA105, 41734424 code offset: 00000000 ffs offset/size [02]: 01C00000/00400000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 01C00000 startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC227E22632260:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC227E22632260:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-Sage_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671 _V1_Z1_ES_DFFA105__system_log_60CFDD31_24447341_20 100926-150209.B0X.bin Finished, time used: 51 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! but phone is still white display and it blinks! plz help! |
09-30-2010, 10:49 | #9 (permalink) | |
Member: 268415 Status: Offline Thanks Meter: 57 | phone came for the unlock. and was working and in the brand new condition. i tried to unlock. here is the 1st unlock log which I've done. phone became black screen with some error then i flashed with firmware from support. here is the 1st unlock log. i don't have original firmware. Quote:
09-30-2010, 19:08 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, if you want to change default unlock settings, make full flash backup - this helps you to avoid many problems. What was the reason to change default unlock method ? Software always select more suitable and safe unlock method for each model ! For your phone it was "smart safe" mode, but you have changed it (but it may be that you show me not original unlock operation log, but any kind other logs). As I can see your phone firmware is newer than firmware that exist in support area and it may be that phone has some kind of new hardware. Let's wait until we will be able to get new firmware for this phone. |
09-30-2010, 21:13 | #11 (permalink) |
Member: 268415 Status: Offline Thanks Meter: 57 | unlock method was changed by mistake as i didnt know it will go wrong and the operational log it original. By the ways thanks for the information. and will wait for the new firmware. thanks Best regards. |
10-20-2010, 14:26 | #12 (permalink) |
Member: 268415 Status: Offline Thanks Meter: 57 | i've flashed the phone with the latest firmware available on the support. phone still dead. here is the log attached. ==== [10/20/2010 6:09:25 PM] ==== COM7 [VCP0] selected module v3.62 Device: ZTE-Sage Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware ZTE-X671_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X671_V1_Z2_ FRES_BFFA102_2010-07-10_SFR-242_En_Fr_Es.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:8203:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: 60CFDD31 rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X671_V1_Z2_FRES_ BFFA102.BIN project-id: X671_V1_Z2_FRES_BFFA102, 4A07FD67 code offset: 00000000 ffs offset/size [01]: 01000000/01000000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 01000000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\MModule\id.60CFDD31.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X671_V1_Z2_FRES_ BFFA102.BIN_67FD074A].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\id.60CFDD31._ZTEMT25_07A _PCB01_GPRS_MT6225_S00.X671_V1_Z2_FRES_BFFA102.BIN _67FD074A_.rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.60CFD D31.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X671_V1_Z2_FRES_ BFFA102.BIN_67FD074A].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.60CFD D31._ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X671_V1_Z2_ FRES_BFFA102.BIN_67FD074A_.rpl ==================== warning: unknown firmware: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X671_V1_Z2_FRES_ BFFA102.BIN_67FD074A Unknown firmware found (v.3.62, database date: 01.10.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X671_V1_Z2_FRES_ BFFA102.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? Area: Firmware flash: EC227E22632260:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: EC227E22632260:18E59F00000000 Finalization Done Finished, time used: 2 min 26 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
