Old 10-23-2009, 08:09   #1 (permalink)
ceedee's Avatar
Member: 5268
Thanks Meter: 24
Zte tmn 2000
I have ZTE TMN 2000 (TMN network branded phone similar to Vodafone 225) here. Is this phone known to be supported?
br
ceedee
The Following User Says Thank You to ceedee For This Useful Post:
Old 12-22-2009, 14:47   #2 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
Yes is almost like vodafone 225...i select vodafone 225 and can read eeprom and flash file
e-gold: 820000
COM37 [VCP0] selected
module v1.71
Device: Vodafone-225
Checking data, wait...
Action: read flash
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0098:0096
Connecting Done
Check hardware ...
sw version: TMN-P108C4FM G V1.0.0B07 Aug 11 2009 09.03.01 21.38.01 09.02.00
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Programas\InfinityBox\Pana01\Vodafone-225_eeprom-static_20091222-134221.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Programas\InfinityBox\Pana01\Vodafone-225_eeprom-security_20091222-134222.B1E.bin
reading eeprom-complete...
file saved: C:\Programas\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20091222-134229.B1E.bin
backup critical area Done
Check memory ...
reading flash...
file saved: C:\Documents and Settings\Тngelo\Ambiente de trabalho\Vodafone-225_flash_20091222-134927.B1X.bin
completed
Finished, time used: 447 sec
Remove/Install battery now !
Old 12-22-2009, 15:07   #3 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
remove user code phone dead
module v1.71
Action: reset
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0098:0096
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Programas\InfinityBox\Pana01\Vodafone-225_eeprom-static_20091222-135018.B1E.bin
loading data...
data loaded
file saved: C:\Programas\InfinityBox\Pana01\Vodafone-225_eeprom-security_20091222-135019.B1E.bin
file saved: C:\Programas\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20091222-135026.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 30 sec
Old 12-22-2009, 16:45   #4 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
BACKUPS files , please help to recover this unit
http://rapidshare.com/files/324418417/tmn_2000.rar.html
Old 12-22-2009, 22:16   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
This phone has at least 8Mb flash chip but V225 has 4Mb flash chip so your backup file is incomplete (it contains only 50% of required data).
Also this phone has new flash chip type that is not supported completely by our software.
You can try to read flash like LG KG370 model and we can try to prepare complete flash file but I am not sure that it will be possible to write flash back.
Pls, send links directly to [email protected] but not post it in forum.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 12-24-2009, 03:40   #6 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
Please check your email
thanks
Old 12-27-2009, 13:11   #7 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
http://forum.gsmhosting.com/vbb/show....php?p=5187955
http://forum.gsmhosting.com/vbb/showthread.php?t=692042
http://forum.gsmhosting.com/vbb/showthread.php?t=838093
problems like me
Old 12-27-2009, 14:06   #8 (permalink)
Member: 130995
Hello,
Flash file uploaded in "main" support area in "TMN" folder.
Yes, I know about problems with new flash chip type, it was the reason why I can not promise anything about your phone.
Old 12-27-2009, 14:13   #9 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
Thanks anyway but i have this error:
if you need i can send and donate you this unit please PM adress.
COM29 [VCP0] selected
module v1.68
Device: LG-KG370
Action: flash write
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0098:0096
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG370_eeprom-static_20091227-131128.B1E.bin
loading data...
data loaded
imei: џџџџџџџџџџџџџџџџџ
reading eeprom-security_џџџџџџџџџџџџџџџџџ...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG370_eeprom-security_џџџџџџџџџџџџџџџџџ_20091227-131130.B1E.bin
reading eeprom-complete_џџџџџџџџџџџџџџџџџ...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG370_eeprom-complete_џџџџџџџџџџџџџџџџџ_20091227-131136.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
repair write error [00800000:0800]...
error: write failed[00800000]
Write Failed
Finished, time used: 66 sec
Old 12-27-2009, 14:20   #10 (permalink)
Member: 130995
module v1.68
Device: LG-KG370
Action: flash write
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0098:0096
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
Write Failed
Hello,
Yes, as you can see this flash type can not be written yet.
Right now it's no need to send phones, we have to make some additional research first.
Old 02-20-2010, 13:43   #11 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
So any news about thisЛЛ????so long time and no suportt
Old 06-30-2011, 23:01   #12 (permalink)
karlux's Avatar
Member: 1218089
Sonork: 100.1615672
Thanks Meter: 8
it worked with me to unlock with VODAFONE_V1.0.0.5881_EXE_ONLY:
1- i connected the phone with cable fgold-049
2- i click unlock but didnt work with the port Com i had selected, i tried with other port Com and worked fine
Software engine version: 1.0.0.5881
Connect phone powered on !
Start auth !
SW Ver: EP-PT-TMN-P108C4FM(G)V1.0.0B07
Imei: 357866030032786
Done;
Press power on !
Starting communication ...
Platform: E-Gold Voice ...
Preloader sent ....
Starting ...
Authorising ...
Loader started ..
MCU ID: 6A 54 08 21 82 B0 01 00 90 0B
Flash ID(0): 0098:0096
Saved: ZTE_357866030032786_EP-PT-TMN-P108C4FM(G)V1.0.0B07_22.56.01_30.06.2011_PARTIAL.b in
Unlocked ! Remove battery and put back !
Time needed - 00:01:21
Old 06-30-2011, 23:47   #13 (permalink)
Haicha's Avatar
Member: 330579
Thanks Meter: 67,512
Start auth !
Done;
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader started ..
Good work.....after 17 Months.
Yes Infinity is one very Good Box.
Regards
Haicha
Any solution to unlock Zte tmn 1010? nofear99 ZTE 8 06-16-2014 22:23
unlock ZTE TMN 2000 GSM PAVIA SAGEM JTAG UNLOCKER 8 12-15-2010 14:30
TMN 2000 Dead with VODAFONE_BETA_v1.0.0.4059 kikodog FuriousGold 8 03-23-2010 22:26
Unlock fail..TMN 2000 Alexandro Monte Infinity-Box 4 03-18-2010 21:21
Zte tmn 2000 pyroz Infinity-Box 2 03-01-2010 19:22
Page generated in 0.25024 seconds with 9 queries
