12-12-2014, 15:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Zte v807 [blade c] WRITTING ERROR Code: Operation : Flash [ v1.07 ] ======= Flash Files set for flashing : [ MCU ] : MT6577__ZTE__ZTE_BLADE_C__CAL-IN-TB1D-P177E01V1.0.0__Android_4.1.1__20130508_111905.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A1CB053010F1 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : ZTE ProdName : P177E01 ProdModel : ZTE BLADE C Device : P177E01 AndroidVer: 4.1.1 MTKxCPU : MT6577 MTKxPRJ : CAL-IN-TB1D-P177E01V1.0.0 ISPFF ID : 6577 TARGET ID : 6575 Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MT6577__ZTE__ZTE_BLADE_C__CAL-IN-TB1D-P177E01V1.0.0__Android_4.1.1__20130508_111905.ispff Init Ok , Sending blocks ... Write failed :( Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:01:41 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594815A177CC17CF0F [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : ZTE ProdName : P177E01 ProdModel : ZTE BLADE C Device : P177E01 AndroidVer: 4.1.1 MTKxCPU : MT6577 MTKxPRJ : CAL-IN-TB1D-P177E01V1.0.0 Saved to : F:\InfinityBox\CM2MTK\Flash\MT6577__ZTE__ZTE_BLADE_C__CAL-IN-TB1D-P177E01V1.0.0__Android_4.1.1__20130508_111905.ispff Done! Elapsed: 00:24:06 Reconnect Power/Cable! |
12-12-2014, 18:54 | #3 (permalink) | |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Quote:
When I get the set it was hang at zte logo I format the set with cm2 but hang @ logo Fortunately customer have same set working condition so I read flash from the set & try to write in flauty set but it gives me error I change the battery but same Now Set is on hang @ logo after that recovery menu comes So now help me | |
12-13-2014, 17:52 | #5 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | when i try to format it ask 4 backup & then i format it Code: Operation : Format FileSystem [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A1CB053010F1 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : not found, will read now ... FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:02:14 Reconnect Power/Cable! |
