Member: 1950912
Sonork: 100.1654643(Offline) Thanks Meter: 403 | Quote:
Originally Posted by JayDi I think there is problem with eMMC. Have no more idea.
It can't pass test - eMMC.
It can't init preloader from FW - eMMC.
It pass DRAM normally. | Sir what you say about this one? Erased full again and tried flash without checking any settings and done it started flashing Phone is starting up now will update you asap with picture Quote:
Operation : Flash [ v1.40 ]
======= Flash
Wait for phone...
Phone found! [ 33 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
BB_CPU_NM : [MediaTek] MT6575|MT6577_S00
Processing BROM stage
i2c Init : 00008810
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v5.1540.01.01
DA Stat : v3.2 on BBID : 0x84
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594815A1B7B056CFC9
[eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB
INT RAM : 0x00020000
EXT RAM : 0x00000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Disabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
DRAM not initialized , will try init now
DRAM init passed , 0x20000000
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Old Dedvice , skip BatteryLevel check
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader.bin
Preloader Init Failed! Looks like HW error or incompatible image
ErrCode :
Operation Failed
Elapsed: 00:00:18
Reconnect Power/Cable!
Operation : HW Test [ v1.40 ]
Wait for phone...
Phone found! [ 33 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
i2c Init : 00008810
SpeedSet : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , HYNIX , 0xE7000000 , 3696 MiB
[eMMC] : CID : 90014A2058494E594815A1B7B056CFC9
[eMMC] : MODE : SQ-WR
[FAILED] : Probably, something wrong with eMMC! Check cable and battery!
Operation Failed
Elapsed: 00:00:15
Wait for phone...
Phone found! [ 33 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
i2c Init : 00008810
SpeedSet : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Processing] RAM Read-Write test
[DRAM] : 0x00000000 , 0 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x00
[DRAM] : DATA BUS test
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:00:13
Wait for phone...
Phone found! [ 33 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
i2c Init : 00008810
SpeedSet : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : Unknown ( Not supported (EmbdedBattery) or Without battery )
All Done!
Done!
Elapsed: 00:00:14
Operation : Flash Erase [ v1.40 ]
User accepted Flash Erase operation!
Wait for phone...
Phone found! [ 33 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
i2c Init : 00008810
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x82
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Erase Flash now ...
Erase whole flash
Flash erase done
Done!
Elapsed: 00:00:10
======= Flash
Wait for phone...
Phone found! [ 33 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
i2c Init : 00008810
SpeedSet : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Setting : HW verify : Disabled
Switching to HSUSB
HSUSB Init Ok
BL : Skip checking by User request!
Use : preloader.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Done!
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash Write Done, time used : 00:02:14
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:02:39
Reconnect Power/Cable! | Thank you for your support!!And the most lovable tool CM2 |
