05-26-2009, 16:49 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 364992 Status: Offline Thanks Meter: 28 | Zte - wp626 error!!!! here is the log WP626 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 3566240172xxxxx file saved: C:\Documents and Settings\PC3\Escritorio\eeprom_3566240172xxxxx_ZTE-WP626_20090522-11xxxx.98E.bin Check flash Done Check space... current eeprom imei: 3566240172xxxxx new imei: 3566240190xxxxx Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... error: wrong write first sector at 0x003FE000 error: errorcode#25 Write Fail Finished, time used: 19 sec Remove/Install battery now ! |
05-26-2009, 19:54 | #3 (permalink) |
Member: 364992 Status: Offline Thanks Meter: 28 | COM5 [VCP0] selected Device: ZTE-WP626 Checking data, wait... Action: imei repair Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98009600000000:38E59F00000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 3566240172xxxxxxxx file saved: C:\Documents and Settings\PC3\Escritorio\eeprom_356624017238945_ZTE-WP626_20090526-15xxxxxx.98E.bin Check flash Done Check space... current eeprom imei: 3566240172xxxx new imei: 3566240192xxxxxx Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... error: wrong write first sector at 0x003FE000 error: errorcode#25 Write Fail Finished, time used: 20 sec Remove/Install battery now ! |
06-02-2009, 18:31 | #9 (permalink) |
Member: 364992 Status: Offline Thanks Meter: 28 | Tried with all baudrate and same error with WP626 and with alcatel S211 all customer in latin america have same problem, there is 2 version, 1 version works all OK but the other ... Booting error.. |
17 Nov 2007: ZTE-WP626 model supported | InfinitySupport | Infinity-Box | 20 | 08-12-2012 13:16 |
Unlocking ZTE T6 Error... [SOLVED] | thugo | FuriousGold | 25 | 06-14-2010 16:07 |
ZTE F230 error ... | zolla | FuriousGold | 9 | 03-17-2010 07:49 |
Unlock ZTE 761 error :::ANSWERED::: | tahataha | PolarBox 3 | 2 | 08-17-2009 22:12 |
zte md2 error | ayasada | Easy-Unlocker | 3 | 03-22-2009 23:20 |
