08-18-2009, 08:53 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | ZTE X761 Dead After Flash module v2.84 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA101_En_Es_Pt_Vodafone-Indie.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:6503:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.EFDEC 292.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A07A10 5.BIN_4A6AE6A7].rpl rom info detection finished device-id: EFDEC292 rom info protocol ver: 04 ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A07A10 5.BIN ver. sw 2: X761_Z0_S_A07A105, 581995B5 ffs offset/size: 00D00000/00300000 ffs address assigned: 00D00000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... firmware patch sp-lock #0/0 applied firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required Special operation Done Write ... detect device sec info... detection phase #1... . detect device sec info finished startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090818-124056.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090818-124956.B0X.bin Finished, time used: 563 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to shahzaadbutt For This Useful Post: |
08-18-2009, 09:30 | #2 (permalink) |
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | i flash again with firmware + eeprom now hang on white screen Code: COM84 [VCP1] selected module v2.84 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z0_S_A07A105_En_Es.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA105__ffs_20090817-142941.B0E.bin Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:6503:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.EFDEC292.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA103.BIN_FDF041C9].rpl rom info detection finished device-id: EFDEC292 rom info protocol ver: 04 ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA103.BIN ver. sw 2: X761_Z2_SF_BFFA103, 36BE0F02 ffs offset/size: 00E00000/00200000 ffs address assigned: 00E00000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device sec info... detection phase #1... . detect device sec info finished startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA103__system_log_EFDEC292_FDF041C9_20090818-131409.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: 98000300000001:18E59F00000000 Write: Eeprom/ffs detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA103__system_log_EFDEC292_FDF041C9_20090818-132422.B0X.bin Finished, time used: 639 sec Remove/Install battery now ! |
08-18-2009, 20:21 | #3 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 727 | Quote:
If your phone doesn't start only solution is to ask Infinity supporters to prepare flash from your backup that is newest. Hope this can help. | |
08-19-2009, 08:37 | #5 (permalink) | |
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | Quote:
plz can u tell me i have read its full flash how can i flash with that readed file? | |
The Following User Says Thank You to shahzaadbutt For This Useful Post: |
08-19-2009, 08:46 | #6 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,425 | Quote:
Send that flash file to infinity they will convert and upload to support then you can do flash !! just upload on Rapidshare or any other file hosting server and post link after some time you will able to get file from support and flash it !! BR Faisal_Computer | |
08-19-2009, 08:59 | #7 (permalink) |
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | here is readed full flash before any operation when phone was locked and 100% ok http://rapidshare.com/files/26840160...17-142532.html plz infinity team convert and upload it on support area please thanx |
08-19-2009, 08:59 | #8 (permalink) |
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | i have flash with this file but phone still dead COM84 [VCP2] selected module v2.84 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA103_En_Fr_Es_Vodafone-Indie.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:6503:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.EFDEC 292.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A07A10 5.BIN_4A6AE6A7].rpl rom info detection finished device-id: EFDEC292 rom info protocol ver: 04 ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A07A10 5.BIN ver. sw 2: X761_Z0_S_A07A105, 581995B5 ffs offset/size: 00D00000/00300000 ffs address assigned: 00D00000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... firmware patch sp-lock #0/0 is not required firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required Special operation Done Write ... detect device sec info... detection phase #1... . detect device sec info finished startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090819-124711.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090819-125613.B0X.bin Finished, time used: 569 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! the phone have originally this firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA105 |
08-19-2009, 10:57 | #9 (permalink) |
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | successfully revived with my backup readed full flash, thanx to infinity team COM84 [VCP1] selected module v2.84 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA105_En_Fr_Es.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:6503:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.EFDEC 292.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A07A10 5.BIN_4A6AE6A7].rpl rom info detection finished device-id: EFDEC292 rom info protocol ver: 04 ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A07A10 5.BIN ver. sw 2: X761_Z0_S_A07A105, 581995B5 ffs offset/size: 00D00000/00300000 ffs address assigned: 00D00000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device sec info... detection phase #1... . detect device sec info finished startup code area #1 check... warning: rpl file not found: C:\Program Files\InfinityBox\MModule\id.EFDEC292.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 05.BIN_0C16B03A].rpl warning: rpl file not found: C:\Program Files\InfinityBox\MModule\id.EFDEC292._ZTEMT25_07A _PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA105.BIN_0C16 B03A_.rpl startup code area #1 backup loaded startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090819-144145.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z0_S_A 07A105__system_log_EFDEC292_4A6AE6A7_20090819-145024.B0X.bin Finished, time used: 545 sec Remove/Install battery now ! |
08-19-2009, 16:20 | #10 (permalink) | |
Freak Poster Join Date: Jul 2005
Member: 158999 Status: Offline Thanks Meter: 41 | Quote:
08-19-2009, 16:26 | #11 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,425 | sorry did not understand !! and if you want to ask any qua , then make a new thread will answer you , and please do not mix the topic BR Faisal_Computer |
zte 335 dead after flash | sneha | Various CDMA/TDMA Cell Phones | 12 | 12-25-2010 15:39 |
Zte x761 dead after repair securite zone | ORACHI | Infinity-Box | 1 | 01-01-2010 18:08 |
zte x761 dead :::ANSWERED::: | MovilCare | PolarBox 3 | 4 | 06-16-2009 14:22 |
Zte 336 dead after flashing | loverajgoyal | Various CDMA/TDMA Cell Phones | 0 | 04-23-2009 08:50 |
Zte 125 dead after flash | luyanda | Infinity-Box | 2 | 01-09-2009 15:31 |
