Old 12-05-2011, 16:39   #1 (permalink)
Member: 1383120
Sonork: 100.1612024
Thanks Meter: 18
zte x930 plz help
I flash zte x930 successfully and phone not turning on, plz help.
here is the log
=== [12/5/2011 9:50:02 AM] ====
COM8 [VCP0] selected
module v3.75
Device: ZTE-X930
Checking data, wait...
Action: write flash NAND
write: Firmware
ZTE-X930_ZTEMT35_09B_PCB01_GPRS_MT6235B_S01.X930_V1_Z1 _EN_B1EF110.BIN_FLNH8ACS0PE0MBR_46M_C_2010-10-13__T-Mobile-E200-Vibe_En.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
nfi area detection...
bootloader version: ZTEMT35_09B_BOOTLOADER_V005_MT6235B_X930_V1_Z1_EN_ B1EF110.bin
nfi area detection (3 cores) finished: Ok
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (115200)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: X930_V1_Z1_EN_B1EF108
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
warning: header is empty: probably flash chip completely erased
warning: can not detect header
nfi area detection (0 cores) finished: failed
warning: ffs can not be detected
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: ZTEMT35_09B_PCB01_GPRS_MT6235B_S01.X930_V1_Z1_EN_B 1EF108.BIN_FLNH8ACS0PE0MBR_46M_C
project-id: X930_V1_Z1_EN_B1EF108, 00000000
code offset: 00000000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
startup code area #1 check...
done
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Disconnect...
done
Finished, time used: 36 min 15 sec
Remove/Install battery now !
Flash phone with firmware from support area !
Old 12-05-2011, 20:22   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
file you used is different from phone's original software
this is a reason of dead phone
B1EF110.BIN
B1EF108.BIN
Old 12-06-2011, 01:00   #3 (permalink)
Member: 1383120
Sonork: 100.1612024
Thanks Meter: 18
thanks alot it works
Old 06-19-2013, 20:51   #4 (permalink)
Member: 1960538
wht tool did u use to flash zte x930? is thr any link to tutorial on how to flash this phone ?
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.16097 seconds with 9 queries
