01-26-2017, 21:52 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: MEXICO
Member: 1318721 Status: Offline Thanks Meter: 166 | zte z988 read fail Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09 Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 007DAF85 ID_BLOCK_I : 009720E1 ID_BLOCK_L : D8ECE05379E35233BA2E34F8161FA071 ID_BLOCK_L : D610C7B792F7DF2AB9A33D672535FB64 Use CM2 Internal Loader Error : Prepare target failed! Unsupported yet CPU! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to kzafquiel For This Useful Post: |
01-27-2017, 08:26 | #2 (permalink) |
Member: 1318721 Status: Offline Thanks Meter: 166 | zte z988 NETWORK Technology GSM / HSPA / LTE LAUNCH Announced 2016, May Status Available. Released 2016, May BODY Dimensions 164.1 x 83.8 x 8.9 mm (6.46 x 3.30 x 0.35 in) Weight - SIM Yes DISPLAY Type IPS LCD capacitive touchscreen, 16M colors Size 6.0 inches (~72.2% screen-to-body ratio) Resolution 1080 x 1920 pixels (~367 ppi pixel density) Multitouch Yes PLATFORM OS Android OS, v6.0 (Marshmallow) Chipset Qualcomm MSM8952 Snapdragon 617 CPU Octa-core (4x1.5 GHz Cortex-A53 & 4x1.2 GHz Cortex-A53) GPU Adreno 405 |
01-27-2017, 08:39 | #3 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | hi infinity team , i think a lot of work still needed on qualcomm module , as many types of cpu and models still not supported hope you got new surprises for your *******rs , you always have the best solutions and support we are waiting for a bomb from you thanks |
01-27-2017, 08:42 | #4 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
We support all, what listed in our update lists. In every update we adding atleast 10-15 SECURE types, which are specific to some brands. Depend on luck and much rest things - we will cover more secure models in next versions, sure. But all it require time, resources, luck and much other things. | ||
