Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > TST Dongle
TST Dongle Total Samsung Tool
Old 01-18-2006, 17:01   #1 (permalink)
Member: 76522
Thanks Meter: 30
still the same problem whis TST
ppl r u kidding? txt 4 relise tst 3.0 but why agere module not work?
but the most kidding is z130 unlock i think u even read your support section or even do not see winimea if your soft still try 2 unlock this model via usb.
pls tell me this mpdel is supported long time ag but still as i read NO ONE unlock NO 1 phone whis tst! its nonsence!
also pinout section is great! 4 3g samsung r 2 pictures named z1xx? 4 u kidding againg? i find at list 3 different pinout z105 z130 z140. is this mean support?
what about other models? i cant flash whis your soft even c230 because soft dont see it and on same comp optiflash work perfect whis it on the SAME cable!
i think that whis new updates some bugs will be repaired but i just found much more bugs!
bad work!
Old 01-18-2006, 17:03   #2 (permalink)
Member: 76522
Thanks Meter: 30
this post at first i want 2 name how 2 unlock z130 but i search and found that tst CANT unlock this model!
Old 01-18-2006, 19:38   #3 (permalink)
SCORPION-1's Avatar
Member: 179938
Thanks Meter: 57
bad work!
lols. i think you need to test ur eyes with doctor . cus you not see something writin on TST V 3.0 ::: BETA ::: which means its with some bugs and thay fix these bugs in full verson .
and about samsung 3g series you must take a look in this section old posts you will see tst unlocked z105 , z500 ,z130 perfectly . and many users tested and post result with screen shots .search and learn how to use tst .dont talk too much nonsense.
scor
Old 01-18-2006, 21:17   #4 (permalink)
porn's Avatar
Member: 134206
Thanks Meter: 17
Getting a bit ****ed off with TST V3.0 will not run on xp with no answer from tst why
Turned to furious same unlock program as tst works much better for me!!!
May be full version will work without bugs
Old 01-19-2006, 08:15   #5 (permalink)
Member: 76522
Thanks Meter: 30
scor
yes its beta but may be on 2.0 full unlock z130 work? dont tell b*llsh*t z130 no way 2 unlock whis z130. read posts i think they even never see this model. they say that flash mode 4 z130 is 9+power when is corect 4+power. and it cant be unlocked whis usb cable but all tst relises want modem drivers so they work whis usb cable. yes ppl unlocl this models but whis different soft but no tst.
p.s. i think full version will came 4 next cristmas!
I reported this problem twice but still the same problem netmos Z3X-Team Products 5 03-10-2010 10:30
V3xx untypical, is on boot mode only, but after flash still the same problem Unlockemall Scout 10 11-13-2009 10:51
s5230 still the same problem not unlocked [Solved] fiftycent112 Z3X-Team Products 2 09-08-2009 14:19
infinity team still the same problem touch screen problem A8+ plz check jcjibz2 Infinity-Box 10 07-27-2008 09:50
Still the same problem with DCT4+ phones!!!!!! Fones_Clinic_Network Universalbox 1 08-13-2007 23:37
Page generated in 0.20962 seconds with 9 queries
