TST Dongle Total Samsung Tool |
03-30-2006, 03:34 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | E315 continue searching after flash after unlock, it cannot accept some SIM from my country ... so, I think maybe software upgrade can solve this ... first, I convert to E316 --> it turns on, but screen shows without back-light second, I convert to E317 --> same as E316 so, I decide to flash back to E315 ... but it cannot find network anymore, it always says' Searching ' .... I saw my customer usiung the phone before she handed to me ... and when she get it back, she put the same SIM into the phone, but just cannot hook up with the network ... ?? any idea?? now I have the phone on hand, willing to use it for any test .... i gave another phone to customer, and she is happy with that ~ |
03-30-2006, 19:09 | #2 (permalink) |
Product Supporter Join Date: Mar 2005 Location: Samsung R&D
Member: 125695 Status: Offline Thanks Meter: 3 | Hello, you're flashed this file E315UVDH1_FULL ? It have 2 part. First deactive repair mode, remove all reserved region. Second flash _1 file after that flash _2 file And, *2767*3855# to make phone reset. If still not have network, do a IMEI rebuild. I don't remember exactly E315 have network band select or not, but i think u must check it first before doing anything |
03-31-2006, 05:02 | #3 (permalink) |
Member: 49581 Status: Offline Thanks Meter: 73 | it didn't have network band selection .. for sure .. it is a dual band phone, 900/1900 i will try flash it tomorrow ... i download the FULL flash, and i saw two files ... i only flash the 2nd part, because i was thinking that the oneending with 2 is newer ... huh ~ |
The Following User Says Thank You to gwaai For This Useful Post: |
04-08-2006, 04:13 | #4 (permalink) |
Junior Member Join Date: Apr 2004 Age: 48
Member: 62897 Status: Offline Thanks Meter: 1 | i have E315, i flash E310 but can not power on. I reflash E315 but my phone now Searching can not sign in my network again. I flashed fullfile and use UFS change imei. What will i do now, thanks. |
The Following User Says Thank You to hymalaya For This Useful Post: |
04-30-2007, 16:34 | #6 (permalink) |
Major Poster Join Date: Oct 2006
Member: 374788 Status: Offline Thanks Meter: 2 | Flasher for e315??? Sorry, not right section for writing. ... What flasher do you use for flashing those two parts: E315UVDH1_1.s3 E315UVDH1_2.sre ????????????????????????? I used OptiFlash 5.0 IT -General: --Samsung SGH-X120/E316/E610/E71x/E810/P730 --Tracks - "1" --Tracks' method - "start from FL" --all other checkboxes - unchecked But when I chose E315UVDH1_1.s3 and press "FLASH", after saying "loading s3 records..." it comes up with an error: ERR_BAD_SREC_ADDR P.S. E315UVDH1_2.sre under the same setting goes right. |
The Following User Says Thank You to oleksasha For This Useful Post: |
10-20-2012, 14:01 | #7 (permalink) |
Junior Member Join Date: Jun 2012 Location: Florida
Member: 1774968 Status: Offline Thanks Meter: 0 | Hey guys I have a SGH-E315 from tmobile that like to flash to have it unlock as a extra phone, already try to get unlock code but wouln't work. All the links to flashing are dead.. any clues?? thank you |
N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] | jus_chillin | Cyclonebox | 19 | 03-29-2010 11:57 |
p910 searching after flash | anam120 | Sony Ericsson | 6 | 03-09-2009 00:24 |
KG200 continue searching | kamransohail786 | LG | 3 | 08-26-2008 14:00 |
e315 no network after flashing.. need help elco!! | ryumahon | NSPRO | 7 | 08-23-2008 18:44 |
e315 no network after flashing.. need help!! | ryumahon | UST Pro II | 3 | 08-19-2008 20:38 |
