Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > TST Dongle
TST Dongle Total Samsung Tool
Old 09-26-2005, 15:49   #1 (permalink)
stigor's Avatar
Member: 9165
TST. Need explanation ...
TST?
I dont have X495 phone model in selection in Sysol models?
I have installer 2.9B2.EXE 14.782MB from 10.9.2005? downloaded
from Dongle2 dir. from support.
First i remove previous version, from CPanel, after
that install new, and all the same?
Give a litlle hint, and write in SW window after installing
what version are installed, always shows 2.9. if that is 2.9B3, put that?
And what is 2.9B_addon.exe? After start, nothing happend??
More explanations?
Old 09-26-2005, 18:06   #2 (permalink)
SCORPION-1's Avatar
Member: 179938
in 2.9b_addon thay fixed some bugs .to remove software bugs.
there is several models which cant change imei correctly and i thin with new addons thay fixed it.
Old 09-26-2005, 18:22   #3 (permalink)
stigor's Avatar
Member: 9165
How to receive X495 in Sysol models? I install 2.9B2 full, first remove B1, after that
2.9B3addon.exe, and after that, not in Sysol unlock X495? Only receive X495 in
SIII-FLasher! TST, i think your installation 2.9B2 (14MB) and 2.9b3addon.exe have
some bug ? Or if anybody succeded to install addon and receive x495 phone type in
Sysol TAB, please to explain how to?
Old 09-26-2005, 18:54   #4 (permalink)
SCORPION-1's Avatar
Member: 179938
plz check this link here u can see x495 unlocking screen shot via tst
x495 unlocker
Old 09-26-2005, 18:56   #5 (permalink)
stigor's Avatar
Member: 9165
Yes, i know, but how to get that feature? I need someone who is succeed with
installation to explain how he did it ...
Old 09-27-2005, 02:51   #6 (permalink)
LogoMan's Avatar
Member: 17431
Originally Posted by stigor
TST?
More explanations?
Here........SWIFT_Unlock 2.9b3 Released.
BR,
LogoMan
Old 09-27-2005, 05:55   #7 (permalink)
stigor's Avatar
Member: 9165
@LogoMan
Yes, i create X495 folder, and X495 shows in selection, but that folder now is empty
not have .INI and .DAT files ? Where to find that files for that model?
Old 09-27-2005, 09:17   #8 (permalink)
Member: 125695
Install 2.8b2 , then run 2.8b3 once. Only run 2.8b3 once. it won't display anything but it's successed!
Old 09-27-2005, 10:24   #9 (permalink)
stigor's Avatar
Member: 9165
What 2.8?? You mean 2.9?
I tryed all, not working. First i tested on one pC where previous installed
2.9b1 version, that work OK. After that uninstall 2.9b1, and install 2.9B2,
that work OK, but when start 2.9B3ADDON, nothing. After each operation of
installation, i restart pC. But nothing. NO Sysol models in Service
selection menu.
Second, i installed on another "clean" PC with XP, first 2.9B2, that
goes OK, but after install 2.9B3ADDON, nothing happend, no in SYSOL
SERVICE x495, x620 etc.
Only when by hand, make dir like x495, in that case show option
x495 in sysol, but i dont have it INI, and DAT files.
So, if you can repair that installation programs, to make work.
Maybe you make installation be possiblle only in C drive?? Can
be installed on D drive?
Or, arhive that DIRs (in TST_S) with DAT and INI files for X495, x620
and other new SYSOL models, and attach on message, then i put that
files in required dirs in TST GOLDEN directory.
Need Explanation for bb5 tjiang_s Universalbox 0 01-06-2008 16:56
need explanation! CLIFFORD25502 UFS2 + UFS3-Tornadoflasher 0 10-07-2005 11:41
I Need Explanation On How To Unlock 9xx With Sagem Doctor sunrise gsm Infineon C16X M51 & ARM7 M52 BASED 14 04-05-2005 15:35
RoEmmi: Need explanations. Deoz Old Legacy Motorola (EMMI) 1 03-03-2003 16:55
Need Explanation rolko_mobile Hardware Repair by brands 0 01-19-2003 21:37
Page generated in 0.32945 seconds with 11 queries
