03-31-2006, 22:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: root
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | 2 x Philips 355 dead Received 4 PH355 to unlock. Ok, used T191 cable, connected and unlocked 2 phones without problems (read phone, then unlock and repair. waited for "powering off phone", they still were in Tat Mode). When checking, before unlocking the other 2, I noticed that both were not working anymore. They turn on, show Philips on screen, and turn off. So, I connected the other 2, but didnīt use unlock function, just read NCK from screen and typed. The 2 that were directly unlocked, donīt work no more. The other 2 that I only inserted given codes, are working perfectly. Direct unlock on Philips 355 via Thunderstorm kills phone? What a major bug is that, and how to make them working again? br |
03-31-2006, 22:10 | #2 (permalink) |
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | just adding info: phone that does not work, done by direct unlock: Version - 0114040618020000 LangPack - WestEurope (45) IMEI - 353896xxxxxxxxx (OTP) NCK - DISABLED NSCK - DISABLED SPCK - DISABLED CCK - DISABLED PCK - DISABLED MCC+MNC - Unknown phone working normally, done by codes (it´s unlocked, despite of the msg) Version - 0114040618020000 LangPack - WestEurope (45) IMEI - 353896xxxxxxxxx (OTP) NCK - DISABLED NSCK - DISABLED SPCK - DISABLED CCK - DISABLED PCK - DISABLED MCC+MNC - Telecom Moveis Nac. TMN Portugal Well, seems that problem is MCC+MNC code. How to put it back? br |
04-01-2006, 07:01 | #3 (permalink) |
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | problem solved, topic may be closed. I didn´t realize before that a security backup was automatically saved. after restoring backup, phones worked again, unlocked using codes, all fine now. br |
04-01-2006, 15:40 | #4 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Inside ThunderStorm Engine
Member: 40070 Status: Offline Thanks Meter: 4 | Your problem is that you do not listen to me. I told to all many times to use workshop and not to use old sw, but seems that you do not understand it. So after next update noone will be anle to use old philips sw anymore. WBR ThunderStorm |
Philips 355 Almost Dead | izvrateniaka | Philips | 2 | 08-17-2006 07:11 |
Problem flashing Philips 355, phone dead! Please help! Urgent! | TaSMi | Philips | 1 | 11-08-2004 22:13 |
philips 355 from amena spain? | ertorry | Redbox | 0 | 06-25-2004 15:47 |
philips 355 amena | twisterdecai | Redbox | 0 | 06-24-2004 14:34 |
