.::100% solution of 5130 & 5310 camera on standby::. .::100% solution of 5130 & 5310 camera on standby::. You must have Mx-key....... And use this file dcc_NIPS_2M_72_2009.XX.XX 'n do this method for write file... You must frist scan fon than whic file show there this versan file write ..... it is 100% solution of this fone ... if it is work please press thankx .... Br. amar181:) |
plz put in this tool link.......................................link add |
It is diffrent file for model and versan ... yes if you need please tell here which model and still runing versan of your mobile........ Br. amar181:) |
and from where to get this file dcc_NIPS_2M_72_2009.XX.XX b |
this tool only happen from solfware not for happen damage hardware thank for share regard jomyutnot |
Under flash file you can found this file .... If you need plz requist here ... when request here give me fone model and file versan ..... Br. amar181:) |
if the problem is in hardware it cant repair by software first have to check software then hardware and mostly this problem is come from hardware i tested 80% is hardware |
i need 6303c v8.90 thanx |
good work.its not bad if we can test it b4 working hw.its more easy if software work br |
It suport 5130,5310 E71... Br. amar181:) |
what abt 2630 and 2600c camera "restart" ? |
thanx Quote:
it is always a hardware problem |
