03-27-2011, 15:58 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | 2x5970 Problem : BF Experts Needed I really need an advice form Brute Force Experts.. I got 6 GPU 5970 . 1 is 4GB and rest 5 have 2GB memory. One Card in one comuter works fine. Without Overclocking , 4gb card give 37-38 sec per salt . 2g card provide 44-50 sec per salt. Now ; I made another computer with AMD Phenom II X6 1100T CPU ASUS Croshair IV Extreme Mother Board Corsair 120GB SSD Force Hard Disk 1200w Power Supply TT PRO Water 850 CPU Cooler 8GB RAM HAF RC-942 Cooler Master Case I thought , this would be a perfect choice... but , Problem is , Pc work for few minutes only. After 2-4 minutes Computer Turns Off by itself or Sometimes Display Driver Stop Responding when i try different drivers I tried with ; version 10.1 10.2 10.4 11.1 11.2 Same issue again.. Can anyone please guide me , what should i do to make it stable.??? LITTLE MASTER |
The Following User Says Thank You to Little_Master For This Useful Post: |
03-27-2011, 17:35 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | no, mr. Pramod, write here your opinion, i'm SOOOO curios to hear what you have to say. after, i will write MY opinion. |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
03-27-2011, 18:04 | #5 (permalink) |
No Life Poster Join Date: Jul 2010
Member: 1356436 Status: Offline Thanks Meter: 269 | No bro it is not any opinion. It faced not only for one exact reason but many problem besides. I have see it on gigabyte site. And so I can help him on teamviewer if he want otherwise nothing. Thanks. |
The Following User Says Thank You to Pramod (F C) For This Useful Post: |
03-27-2011, 22:06 | #6 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
cool. @Little Master ... the first few things that you need to check are (one by one) - try with other Power Supply, (you need some brand-name 850W PSU) - try with one card, if still the same, try with another card - i hope you are using drivers v10.11 as i wrote already - and i hope you are using latest motherboard drivers from site - and i hope you dont have anything irrelevant installed on that PC, like 100 different utilities, photoshop, office, antiviruses, and other crap - and i hope you didnt push too high overclocking for those cards so ... post what you did, and did you succeed in fixing the problem. i doubt that you have problems with board/ram/cpu ... check one by one as i wrote. b.r. Alexandar | |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
03-28-2011, 04:34 | #7 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | @Pramod (F C) Thanks for reply.. I'll add you in my msn and we will talk. @Brka You are expert with Brute Force. I have read all your post regarding Brute Force and i believe that you are experienced person . I 'll try all your Suggestions and will post my result soon. Thanks LITTLE MASTER |
03-28-2011, 04:48 | #8 (permalink) | |
last few cases with similiar problem like yours, were caused by power supply so that goes first. i pray that it's not a card isuue ... i also wrote how to check that ... both cards inside, put another PSU, start FurMark (Multi-GPU) and burn it, if it crashes ... you know then. after ... put just one card ... if goes well, than another. btw. i didnt become expert with coming of bruteforce, i worked for years as pc-service repair person, one of my favourite hobbys, beside networking is PC's and PC Hardware; plus I spent a lot time with overclocking teams from our country, and as i wrote to harry ooXTCoo, i have seen everything that can be seen, overclocked everything that can be overcloked, and all pc's and hardware i have is overcloked and rock stable working for long time ... that would probably mean something wish u luck man post later what was the problem, ok ? (when u fix it) p.s. thanx for nice words about me b.r. Alex | |
The Following User Says Thank You to Brka For This Useful Post: |
03-28-2011, 12:13 | #9 (permalink) |
Registered User Join Date: Jul 2006 Location: iphone ww codes Age: 42
Member: 305964 Status: Offline Thanks Meter: 71 | i have the same problem my friend .. mine is this my rigs: 1pc5970 2pcs5870 trifire msi bigbang fusion motherboard 8gb ram geil 500gb hd 1000watts cooler master silent during bruteforce operation its stop error like this rtc.exe stopped worked and amd driver has stop responding but succesfully recovered im using catalyts 11.1 windows 64 bit ive try diffrent driver from 10 to 11 nothing different lower voltage upper voltage the same if im using 10.7,10.11 works fine but gpu usage not fully loaded like 97up then 85 down its something flactuating.. can anybody analyse my problem before i change ax1200 corsair psu let me read your words about this.. please help us ,, icant eat icant sleep about this not working stable.. tia br. ernestgsm |
03-28-2011, 12:34 | #10 (permalink) |
No Life Poster Join Date: Dec 2004 Location: hong kong
Member: 95653 Status: Offline Sonork: 100.1585508 Thanks Meter: 110 | I Have 3 Machine all with 2*HD 5970 1. 2* HD 5970 10.11 cat driver Oc to 841 Mhz Temp : 50 ,47 ,47,51 Water cooled salt :19.7......20.2 2. 2*HD 5970 10.3a cat driver OC 801 MHZ TEMP : 55 , 51,45,44 water cooled SALT : 20.4 constant 3. 2*HD 5970 10.11 cat driver Temp : 66,65,63,62 Air cooled OC 841 MHZ Salt : 19.4....19.9....20.0 All system are very stable never restart problem PSU : silver stone 1000w |
The Following 2 Users Say Thank You to afrar For This Useful Post: |
03-28-2011, 14:45 | #11 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | Code: Software will process now queue in loop. That means you can add LOG files during calculation, so it will be calculated once finished. Important Notice: DON'T remove "COD" files after calculation, else software will calculate COD file for same phone again. GPU Selftest Started... Trying salt 559 Seconds Remained: 12.3 NCK Found GPU Selftest Passed OK! Processing all logs in queue... Restored TryTable, Entries : 8 Trying salt 5544 Seconds Remained: 23.3 NCK Not Found Trying salt 5579 Seconds Remained: 31.0 NCK Not Found Trying salt 4787 Seconds Remained: 23.3 NCK Not Found Trying salt 4630 Seconds Remained: 23.3 NCK Not Found Trying salt 4659 Seconds Remained: 23.4 NCK Not Found Trying salt 2772 Seconds Remained: 22.9 NCK Not Found Trying salt 7932 Seconds Remained: 23.4 NCK Not Found Trying salt 9523 Seconds Remained: 23.4 NCK Not Found Trying salt 5609 Seconds Remained: 31.1 NCK Not Found Trying salt 1952 Seconds Remained: 23.9 NCK Not Found Trying salt 2059 Seconds Remained: 38.8 NCK Not Found Trying salt 7467 Seconds Remained: 25.0 NCK Not Found Trying salt 3181 Seconds Remained: 26.5 NCK Not Found Trying salt 2639 Seconds Remained: 55.7 NCK Not Found Trying salt 3253 Seconds Remained: 24.5 NCK Not Found Trying salt 3429 Seconds Remained: 63.3 NCK Not Found Trying salt 1810 Seconds Remained: 23.4 NCK Not Found Trying salt 2888 Seconds Remained: 25.0 NCK Not Found Trying salt 2494 Seconds Remained: 26.0 NCK Not Found Trying salt 593 Seconds Remained: 26.5 NCK Not Found Trying salt 4921 Seconds Remained: 26.5 NCK Not Found Trying salt 318 Seconds Remained: 51.1 NCK Not Found Trying salt 5227 Seconds Remained: 22.9 NCK Not Found Trying salt 4260 Seconds Remained: 25.0 NCK Not Found Trying salt 2327 Seconds Remained: 26.5 NCK Not Found Trying salt 7342 Seconds Remained: 25.5 NCK Not Found Trying salt 4719 Seconds Remained: 26.5 NCK Not Found Trying salt 2720 Seconds Remained: 26.0 NCK Not Found Trying salt 8591 Seconds Remained: 27.0 NCK Not Found Trying salt 1202 Seconds Remained: 37.7 NCK Not Found Trying salt 9312 Seconds Remained: 23.4 NCK Not Found Trying salt 5953 Seconds Remained: 26.0 NCK Not Found Trying salt 4014 Huge Problem Solved .. but Speed not stable. actually , one card was faulty .. i put another card , reinstall windows and using driver 10.11 One GPU have 5970 Accelero Xtreme Attached. another is normal both card brand new pc have water cooling and cooler master casing space between two card is more then 2 inchs but tempratue is 99 degree and gpu usage goes 98% - 65% 0 % and 85 % What else should i do . I making my pc super cool but gpu still hot. LITTLE MASTER ps .. GPU has NO overclocking at all working on clock 725mhz and memory 1000mhz |
03-28-2011, 16:38 | #13 (permalink) | |
Member: 1356436 Status: Offline Thanks Meter: 269 | Quote:
Or it also depend on system configuration. I have add you on msn. When you come online then I will fully solved your problem by teamviewer and also explain you how to install card for better perfomance. Br, Pramod yadav | |
03-28-2011, 16:43 | #14 (permalink) | |
Freak Poster Join Date: Oct 2007 Location: hongkong
Member: 602148 Status: Offline Thanks Meter: 16 | Quote:
No impossible ., | |
03-28-2011, 16:43 | #15 (permalink) | |
And I know Sir, You r big in age with me and also you are head in forum compare to me. But I also doing same buisness and I have better experience abt cards and installation tips. Br, Pramod yadav | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
