Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 02-11-2010, 06:31   #1 (permalink)
Member: 890267
3110 calculator not found afther flash
3110 during flash calculator not found ,
Old 02-11-2010, 06:37   #2 (permalink)
Member: 513210
use version 7.21 mcu
7.21ppm a
7.21 images a
your problem will be solved...
Old 02-11-2010, 06:42   #3 (permalink)
Member: 199814
Flash the same phone again as u flashed it via usb... and not on dead mode!
Old 02-11-2010, 07:26   #4 (permalink)
watari31's Avatar
Member: 141262
i experience this kind of problem solution i do is
flash it with 128k cnt
lets say 7.21 mcu 7.21 ppm 7.21 cnt it would/nt have any application or tones or calculator even..
you have to use ver 7.21 cnt_128k or 7.01 cnt_128k it would have a calculator ringtones and other application...
you try also you flash it on usb mode... good luck
Old 02-11-2010, 07:56   #5 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
try flash with same produt code.your problem will solved
Old 02-11-2010, 08:00   #6 (permalink)
Member: 1150025
mate when flashing just check force 128k with the cnt.
Old 02-11-2010, 08:15   #7 (permalink)
[ABDULLAH]'s Avatar
Member: 1021182
brother if u now salution when post other wiz don't make any spam post
tell him the whear he found this file withc is needed thanks
ABDULLAH81
Old 02-11-2010, 08:25   #8 (permalink)
Member: 783116
flash it with mcu version 7.21
7.21 ppm t
7.21 cnt t
tested by me
Old 02-11-2010, 08:43   #9 (permalink)
Member: 36715
Just flash with cnt file
Old 02-11-2010, 09:11   #10 (permalink)
Member: 1150025
http://62.0.5.135/i646.photobucket.c...calculator.jpg
Old 02-11-2010, 09:25   #11 (permalink)
Member: 299534
Sonork: 100.1586632
Smile No Problem
its only flash problem to make a flash letest version 7.21 i try it 1000%
Old 02-11-2010, 09:43   #12 (permalink)
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727
Check Your Mobile Back Side, Product Code & Adjust Recent After Only Cnt File Flash .
I hope Your Problem is solved.
Old 02-11-2010, 10:05   #13 (permalink)
Member: 709604
try it to this file http://rapidshare.com/files/307752979/3110_cal.rar
Old 02-11-2010, 10:45   #14 (permalink)
.:iTRi:.'s Avatar
Member: 240068
CAN U UPLOAD 7.21 cnt_128k HERE
Old 02-11-2010, 11:07   #15 (permalink)
CHEZRACHID's Avatar
Member: 136492
download flash version 7.21 & install it. Flash the phone using ini.file ( auuto detect mcu+ppm+cnt+...), your gonna find your calculator in Organizor floder.
good luck.
Nokia 3110c after flash calculator not found 100% solution mohammedtvl Cyclonebox 9 07-28-2010 07:10
3110c after flash calculator not found 100% solution here vaghubha_sodha Nokia Hardware & Hardware-Repair Area 1 03-21-2010 08:44
Nokia 3110c after flash calculator not found 100% solution Dooha_Bd Nokia Hardware & Hardware-Repair Area 9 01-25-2010 08:14
Nokia 3110c after flash calculator not found 100% solution faisal4friend Nokia Base Band 5 ( BB-5 ) 5 12-04-2009 11:00
Nokia 3110c after flash calculator not found 100% solution mohammedtvl Cyclonebox 0 10-29-2009 11:19
Page generated in 0.43243 seconds with 11 queries
