03-21-2010, 09:05 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Djemboet City, Alaska
Member: 712974 Status: Offline Thanks Meter: 55 | 3110c blink nokia i try full errase with jaff and mx key.. full flash... but not local mode... just blink... help me.. any solution in here.. thanks... |
03-21-2010, 09:59 | #2 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1247853 Status: Offline Thanks Meter: 71 | just the phone connect with mx-key press - bus check then copy the information detail here. i mean to say post your phone bus check detail. after that i will give u the solution..... |
03-24-2010, 17:20 | #5 (permalink) |
Junior Member Join Date: Mar 2006
Member: 243459 Status: Offline Thanks Meter: 0 | RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Total erase size: 10.75 MB CMT NOR area [01520000-01FDFFFF] erased in 1 min 1.062 s Flash programming ... Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x01604000, Result: 0010 Flashing terminated with error(s) in 6 min 16.687 s RX Buffer: C7012D0103CD000010000000F172 |
03-24-2010, 17:30 | #6 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
full erse with erase file after erase flash with any version after flash write npc data with CCC and HWC (ccc and hwc From Clone Rpl) then check local or test mode 100% come (Dont write full rpl just NPC CCC AND HWC) after local or test mode came repair simlock with mx key repair SD after repair SD write full Pm with Super SD Auth And Dont Skip Rewrite simlock option ..:Tested:.. | |
06-21-2010, 20:56 | #9 (permalink) |
Junior Member Join Date: Nov 2007
Member: 632756 Status: Offline Thanks Meter: 0 | nokia 3110c bilink only after write imei ,i try full errase with jaff and mx key.. full flash... but not local mode... just blink... even new v flash file 7.30 but same rsult. heeelp meee plsssssss. sir |
3110c BLINK | mahesh123 | Nokia Hardware & Hardware Repair | 6 | 07-23-2009 17:35 |
3110c blinking | aboymaligalig | Nokia Base Band 5 ( BB-5 ) | 12 | 05-24-2009 20:18 |
3110c blinking after downgrade | manpikin | MT-BOX | 2 | 12-20-2007 10:34 |
