08-29-2009, 06:48 | #1 (permalink) |
Junior Member Join Date: Sep 2007 Location: Andhra Pradesh, India
Member: 596236 Status: Offline Thanks Meter: 9 | 3110c problem while flashing |
01-17-2010, 10:19 | #5 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 613537 Status: Offline Thanks Meter: 26 | change the cable & after that press check button , info button , if it is okay go for flashing , also fix cable properly or fix it with the help of 2 or 3 rubber band , this will help u , all the best . |
01-17-2010, 17:38 | #6 (permalink) |
Junior Member Join Date: Jan 2008 Location: cepu ,indonesia
Member: 676055 Status: Offline Thanks Meter: 2 | i was try ur all solution..but still have same problem...i have cable so good ..n work in another 3110c i think there suplay stripe voltage power to pin out ist having trouble can anybody help me to give ....jumper trick to do that |
01-17-2010, 17:56 | #7 (permalink) |
Member: 676055 Status: Offline Thanks Meter: 2 | [IMG]file:///C:/DOCUME%7E1/LESEHT%7E1/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]1ST BOOT : C0,07 [Rm-237] [2.0.9.0] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 28800210ACCA7C56E2DBF6F4591862DF4BAFEA23 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898981-00006A21, Int NU48F256 CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm237__07.21.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00020000-0007FFFF CMT NOR Erase Area: 0x00080000-000DFFFF CMT NOR Erase Area: 0x00100000-001FFFFF CMT NOR Erase Area: 0x00200000-0031FFFF CMT NOR Erase Area: 0x00320000-0105FFFF CMT NOR Erase Area: 0x01060000-01067FFF CMT NOR Erase Area: 0x01068000-0107FFFF CMT FLASH ERASE OK, Time: 00:04 DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_BLK_ERROR at: 0x00000400, 03 ERR: CMT FLASH WRITE D_BLK C7012D0103CD000090000000F172, LN: 0x0000A0, Time: 00:23 Process Failed, Repowering Mobile |
3110c dead while flashing with HWK | gsmsikar | HWK | 3 | 11-03-2009 17:55 |
3110c dead while flashing , what is the problem ? | gsmsikar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 08-01-2009 14:56 |
Problems while flashing NPL-1 | lexwon | Phoenix Black Box | 0 | 02-02-2005 11:28 |
Problem while flashing with DIV under XP | airboy | DIV | 0 | 10-31-2004 17:14 |
V50 f0.14.04 strange problem while flashing | KaToT | Motorola Old Legacy (EMMI) | 4 | 11-08-2003 14:46 |
