Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 05-28-2009, 05:18   #1 (permalink)
Member: 248182
Thanks Meter: 786
5130 Charging Not Supported
Dear All,
I Have Nokia 5130 (brand new) Phone & the Problem is Charging Not Supported.
Rgds
Bluffmaster
The Following 6 Users Say Thank You to bluffmaster For This Useful Post:
Old 05-28-2009, 05:21   #2 (permalink)
Member: 239004
Sonork: 100.1589817
Thanks Meter: 388
bro check your imei
Originally Posted by bluffmaster View Post
Dear All,
Rgds
Bluffmaster
bro check your imei if 12345789 then its RPL peroblem
if ok then its hardware peroblem use serch butten
The Following User Says Thank You to waqas_ali601200 For This Useful Post:
Old 05-28-2009, 18:33   #3 (permalink)
Member: 248182
Thanks Meter: 786
hi
Phone imei is fine & i already use Search Button But Can Not Find solution Becuase Its New Phone For Forum.
The Following User Says Thank You to bluffmaster For This Useful Post:
Old 06-07-2009, 08:56   #4 (permalink)
Member: 239004
Sonork: 100.1589817
Thanks Meter: 388
check thi link bro use serch buten befor postttt
hi
http://forum.gsmhosting.com/vbb/show...t=5310+charger
The Following 6 Users Say Thank You to waqas_ali601200 For This Useful Post:
Old 06-19-2009, 05:25   #5 (permalink)
Member: 248182
Thanks Meter: 786
Bro I Need 5130 Charging Solution Not a 5310 ...
So Please Read Before Post...
Rgds
Bluffmaster
Old 08-10-2009, 20:23   #6 (permalink)
Member: 420244
Thanks Meter: 41
hi i have same problem any one solve this problem ----???
The Following User Says Thank You to nikgolf For This Useful Post:
Old 08-20-2009, 05:20   #7 (permalink)
suntysunty's Avatar
Member: 226172
Thanks Meter: 946
The Following 2 Users Say Thank You to suntysunty For This Useful Post:
Old 08-23-2009, 07:02   #8 (permalink)
55533faisal's Avatar
Member: 748991
Thanks Meter: 175
5310 charger not suported
The Following 10 Users Say Thank You to 55533faisal For This Useful Post:
Old 08-24-2009, 10:41   #9 (permalink)
zht
Member: 596172
Thanks Meter: 3
check BSI thermistor R2071 AND R2072
IT MAY BE NEED TO CHANGE.
CHARGER NOT SUPPORT NORMALY COMING BSI THERMISTOR......
The Following User Says Thank You to zht For This Useful Post:
Old 08-24-2009, 10:46   #10 (permalink)
zht
Member: 596172
Thanks Meter: 3
Old 08-24-2009, 16:02   #11 (permalink)
Member: 420244
Thanks Meter: 41
pls u have image with resistor located -=?
Old 08-24-2009, 17:42   #12 (permalink)
Member: 420244
Thanks Meter: 41
brow i need 5130 nooo 5310
QUOTE=55533faisal;4774171][/QUOTE]
The Following 7 Users Say Thank You to nikgolf For This Useful Post:
Old 08-25-2009, 06:08   #13 (permalink)
Crazy Poster
Member: 1089314
Thanks Meter: 10
nokia 5130 on/off does not work ............ auto cherging auto show and 5310 charger not suported problem .....................................Please help me anybody....
The Following 2 Users Say Thank You to RASEL TELECOM For This Useful Post:
Old 09-04-2009, 01:41   #14 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Thanks Meter: 368
[/QUOTE]
if you cant find, search for 6120c as they are the same chip
The Following 5 Users Say Thank You to magixian For This Useful Post:
Old 10-31-2009, 10:35   #15 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,539
http://forum.gsmhosting.com/vbb/show...=628281&page=3
The Following 13 Users Say Thank You to ..::ohm::.. For This Useful Post:
5130 Charging Not Supported solution goherabbas Nokia Base Band 5 ( BB-5 ) 11 09-04-2011 08:17
Charging not supported..... and.....Not charging 100% solution R@ZIB-BD Nokia Hardware & Hardware Repair 20 04-06-2010 08:57
i have tyr 5130 is not support [ Its SL3, is not supported !!! ] ABDULLAHI MUHD Cyclonebox 1 01-25-2010 19:57
NOKIA Charging Not Supported & Not Charging NEW HARDWARE EXE dulal044 Nokia Hardware & Hardware Repair 2 05-16-2009 15:33
Page generated in 0.20524 seconds with 9 queries
