01-25-2012, 14:09 | #1 (permalink) |
Freak Poster Join Date: Jan 2012
Member: 1711671 Status: Offline Thanks Meter: 11 | 5130 contact service after flashing Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35524603116412-2 Product code: 0577793 Battery voltage: 4728 mV, current: 0 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NIMMIIIIRRFF0A021001, ver: 002.007 SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355246031164122 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
01-25-2012, 14:13 | #2 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Living with mobile phones
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | Quote:
The Following User Says Thank You to ..::MOBILES::.. For This Useful Post: |
01-25-2012, 14:45 | #3 (permalink) |
Member: 1711671 Status: Offline Thanks Meter: 11 | Wat's this........dear Scanning local SX4 Card ... No SX4 Card found. SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.2 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Aborting operation ... Operation aborted by user request! |
01-25-2012, 15:05 | #4 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Nepal
Member: 952313 Status: Offline Sonork: Coolboy Thanks Meter: 26 | if you have mx box use it mx key no more working now.in mx box just do sd repair it is now standalone no internet connection needed |
The Following User Says Thank You to surendra777 For This Useful Post: |
01-25-2012, 19:06 | #6 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | Quote:
u have mx box or other box??? and remember to post correct product selection. B,R-chamisrilanka | |
The Following User Says Thank You to .::Gsm_Srilanka::. For This Useful Post: |
06-20-2013, 20:45 | #8 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1648224 Status: Offline Thanks Meter: 0 | Phone type: RM-781 (Nokia 300) SW version: V 07.57 24-08-12 RM-781 (c) Nokia Imei plain: 35168605163031-8 Product code: 059J8D6 Battery voltage: 3710 mV, current: 176 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 0F03F840002004, ver: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 351686051630318 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
06-25-2013, 17:53 | #9 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Bd+Bh Age: 39
Member: 1775502 Status: Offline Sonork: 100.1618378 Thanks Meter: 221 | Thumbs up all security test failed 100% solution! all security test failed 100% solution! Many people posted in this forum about security test failed ! we know that when come security test failed solution 1. super sd auth or pmm auth than write good or modified pm ( must need pm 1 & 309) or, 2. sd repair super sd auth or pmm auth than write good or modified pm ( must need pm 1 & 309) yes! we have this solution 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) 7. erase pm again 8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert) 9. give full factory reset your phone must come back from security test failed it is 100% tasted by me. Don't forget to press thanks button ! |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
