Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 03-08-2010, 03:04   #1 (permalink)
Biocell's Avatar
Member: 597789
Thanks Meter: 147
5130 Contact service solutions (security and simlock)
Solusi 5130c Contact service (Simlock and security)
5130c RM 495, is Nokia BB5 of SL3 category... therefore, many people say that this type is not supported for unlock and simlock repair as well as contact service reparation.
Is it true........???
Hmm.....before elaborating the facts, there is an important question: what is SL3 or Security Level 3?
We better understand from the beginning......SL1, SL2, SL3..........
There is a lot of informations in many forums but each explains differently. However, based on my concern and belief, those are classified as the followings:
SL1(Security Level 1) = Nokia BB5 first generation which doesn’t have PM 120 area
SL2(Security Level 2) = Nokia BB5 with PM120 area and the area contains simlock data connected to PM308 value
SL3(Security Level 3) = Nokia BB5 with PM 120 area and PM308 area is protected
I’m very welcoming for any correction.........
Based on the above classification, the next question is “what can be and cannot be done on that each type???
SL1
Flashing = can be done
Write PM 1 and PM 309 = can be done (using SX4, reset NPC, BYPass CRT)
Write PM seluruh area = can be done
Write RPL = can be done
Unlock = can be done
SL2
Write PM 1 dan PM309 = can be done (using SX4, reset NPC, Bypass CRT)
SL3
Write PM area 308 = cannot be done
Unlock = cannot be done
NB: SX4 process through bypass certificate sometimes not perfect.....hence, it is suggested to use SX4 Auth via server...
5130c(RM 495) = Nokia BB5 SL3, Is it possible to fix contact service case on this handphone????
First, we better understand on how contact service case emerge....
Contact Service
“This faults means that the phone Software is able to run and thus watchdog of CPU can be served.
Selftest Functions run when power is switch on and software is executed from combo memory. If any selftest fail, a “Contact Service” text is shown on LCD.”
The point is, when handphone switched on, then cpu will perform several test (selftest). If one of selftest fail, then “contact service” will show on LCD.
Generally, failure is caused by selftest failure on security test and simlock test........
Security Test is related to PM 1 and PM 309 value, if one of or both value within the area is not valid, then selftest result on security test will be failed. Then comes “contact service”.
Solution : re-write area PM 1 dan PM 309 using valid valuei
Simlock test is related to PM 120 and PM 308 value, when one of or both value within the area is not valid, then selftest result on simlock test will be failed. Then comes “contact service”.
Solution :
1. If the problem is on PM 120 value, you can try to re-write that area using valid backup (if you have). But if you don’t have, just make your own PM 120 section 0 using some existing tools free, then ty to re-write the area...
2.
If the problem is on PM 308, seems that no tool is able to fix it recently because PM 308 is protected, can’t be re-written (some says it could be by using some tricks).
What I believe is, PM 308 area has little possibility to corrupt because the area is protected, so if you have contact service problem caused by simlock test failed, it maybe mostly because of corrupted PM 120, not PM 308.
Exampleof log caused by corrupted PM 120...
Log by JAF
Default SN type:
IMEI plain: 354223031265333
IMEI spare to net: 3A 45 22 03 13 62 35 03
IMEI SV to net: 33 45 22 03 13 62 35 23 F6
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 0000000000000000
Provider: Unknown provider
Key Code count: 0, FBUS Code count: 0
Log by MXKey
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 06.65 01-04-09 RM-495 (c) Nokia
Imei plain: 35932902982888-6
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Additional for UNLOCK......
“5130c is Nokia SL3, not support unlock, wait for update...” this is true, but this sentence often put on a wrong place so i think rather misleading.
The above log is not because handphone locked, but because one of simlock data (PM 120 area) corrupt. So, just fix it, no need unlock.
Unlock Provider is a process of opening provider key installed to nokia handphone that is locked on certain provider. Because one of simlock data is located on PM 308 area, so unlock cannot be executed for this moment, PM 308 is protected from re-write operation process through flash mode.
Thanks for OM togel Mania, Om Andra, Om G-blues, else....
The Following 28 Users Say Thank You to Biocell For This Useful Post:
Old 03-30-2010, 12:36   #2 (permalink)
sushilsoni2003's Avatar
Member: 99115
Thanks Meter: 91
Does any one repaire that condition 5130 with pm 120 repair ??
SIMLOCK invalid!
The Following 2 Users Say Thank You to sushilsoni2003 For This Useful Post:
Old 03-30-2010, 12:53   #3 (permalink)
Biocell's Avatar
Member: 597789
Thanks Meter: 147
i dont know...i dont have mxkey on that day....
but i have done repair contact service because simlock.... using pm120 repair...
cek this thread....
5130 contact service
The Following 2 Users Say Thank You to Biocell For This Useful Post:
Old 07-05-2010, 16:26   #4 (permalink)
rafi_5217705's Avatar
Member: 627475
Sonork: 100.1594828
Thanks Meter: 1,020
Nokia 5130 contact service solution Nokia 5130 some solution here................
The Following 4 Users Say Thank You to rafi_5217705 For This Useful Post:
Old 12-17-2010, 14:57   #5 (permalink)
Member: 1282839
11oo light not working plzzzzzzzzzzzzzzzzzzzzzz help meeeeeeeeeee
The Following User Says Thank You to Jiyas For This Useful Post:
Old 02-03-2011, 12:57   #6 (permalink)
Member: 1420901
Thanks Meter: 17
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
I need help pls help me.
The Following User Says Thank You to NUR ISLAM For This Useful Post:
Old 02-03-2011, 16:43   #7 (permalink)
Member: 627475
Sonork: 100.1594828
Thanks Meter: 1,020
Originally Posted by NUR ISLAM View Post
SIMLOCK invalid!
yes now posable to mt-box but some expensive
The Following User Says Thank You to rafi_5217705 For This Useful Post:
Old 02-03-2011, 16:51   #8 (permalink)
rahulk99k's Avatar
Member: 485686
Thanks Meter: 539
yet no have solution for 5130 contact service
The Following User Says Thank You to rahulk99k For This Useful Post:
Old 02-03-2011, 16:57   #9 (permalink)
GOLDEN-SHARIF's Avatar
Member: 66430
Sonork: 100.1601372(iN YoUr mInD)
Thanks Meter: 1,978
The Following User Says Thank You to GOLDEN-SHARIF For This Useful Post:
Old 03-03-2011, 11:34   #10 (permalink)
Member: 760926
Sonork: 1893:010E
Thanks Meter: 4
100% solution 60 credit with cyclone box
The Following User Says Thank You to parvez ahmad For This Useful Post:
Old 03-03-2011, 14:21   #11 (permalink)
Member: 1441250
Sonork: 100:1602230
Thanks Meter: 199
Arrow
Contact Service
Solution :
2.
100% solution 80 credit with mt box
The Following User Says Thank You to Sarder For This Useful Post:
Old 03-07-2011, 08:20   #12 (permalink)
rahulk99k's Avatar
Member: 485686
Thanks Meter: 539
good post..............
Old 03-07-2011, 14:39   #13 (permalink)
zorgy_1979's Avatar
Member: 1331464
Thanks Meter: 143
1000% fake. reset npc also repair CS but it is not solution.
Old 03-23-2011, 22:37   #14 (permalink)
Member: 687718
Sonork: 100.1603913
Thanks Meter: 121
may i ask
cek this thread....
dear you solve contact service may i ask what is the steps to make pm120 via JAU
PLZ POST FULL PROCEDURE WITH IMAGE IF POSSIBLE
THANKS IN ADVANCE
The Following User Says Thank You to manishavar15 For This Useful Post:
Old 05-03-2011, 12:57   #15 (permalink)
Member: 583410
Thanks Meter: 7
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
plzz help me about this 5130
5130 contact service (ANSWERED) vishal123123 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 08-10-2011 12:05
any nokia 5130 contact service solution sushilsoni2003 Nokia Base Band 5 ( BB-5 ) 4 04-05-2010 03:37
the diffrent 5130 contact service by security or simlock ekel MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-23-2010 16:49
5130 contact service solution ? asifdogar Universalbox 1 12-27-2009 17:40
How to fix a 5130 contact service (no simlock and no superdongle) shaazad Trash 2 12-26-2009 11:33
Page generated in 0.53668 seconds with 8 queries
