10-07-2010, 10:30 | #1 (permalink) |
Freak Poster Join Date: Aug 2010
Member: 1379727 Status: Offline Thanks Meter: 617 | 5130-successfully-contact-service-repair 5130c RM 495, is a handphone nokia BB5 SL3 categories ... and because it was so many people say the phones are not support for the process simlock unlock and repair ... and repairs ervice Contacts .... Things true .........................??? Um .... before we parse the facts, there is an important question .... what SL3 or Security Level 3? Should we understand from the beginning ..... SL1, SL2, SL3 .......... A lot of information circulating on various forums and each one is slightly different, but more or less following the division according to what I understand and believe: SL1 (Security Level 1) = Nokia BB5 early generations who do not have areas of 120 PM SL2 (Security Level 2) = Nokia BB5 that have PM120 areas and simlock area contains data that are connected with the value PM308 SL3 (Security Level 3) = Nokia BB5 that have areas of PM 120, PM308 and protected areas Based on the distribution of the above, what can and what can not be performed on each of these types of mobile phone? SL1 Flashing = can be done Write PM 1 and PM = 309 can do (using the SX4, reset the NPC, Bypass CRT) Write PM all of area = could do Write RPL = Can be done Unlock = can be done SL2 Flashing = Can be done Write PM 1 and PM309 = Can be done (using the SX4, reset the NPC, Bypass CRT) Write PM all of area = Can be done Write RPL = Can be done Unlock = Can be done SL3 Flashing = Can be done Write PM PM309 = 1 and could be done (using the SX4, reset the NPC, Bypass CRT) Write PM area 308 = Can not be done Write RPL = Can be done Unlock = not done NB: the SX4 with the way the bypass Cert results are sometimes not perfect ... therefore recommend to use SX4 at Auth via the server. Test security is related to the value of PM 1 and PM 309, if the value in both areas there is an invalid ... the results of selftest in the security test will be failed / failing. The result is "contact service". Solution: re-write the area AM and PM 309 to the first valid value Simlock test associated with the value of PM 120 and PM 308, if the value at the proficiency level in these two areas there that are not valid, then the results of selftest in Simlock test will be failed / failing. The result is "contact service". Solution: 1. If the value of AM 120 with problems, if you have a valid backup, can be tried to write over these areas. If not, create your own PM 0 section 120 using a variety of free tools 2. If the PM 308 is problematic, it seems there is currently no tool that is able to fix it, because the PM 308 protected areas, can not re-write (some say could ... with a little trick) available, then try to re-write the area ... I believe, that a small area of AM 308 could probably corrupt, because the area is protected ... so if you have a problem contact service for simlock test failed, then most likely due to a corrupt area of 120 PM, not AM 308 area. Examples PM 120 log because of a corrupt ... I think its possible....cause PM 308 cannot corrupt/modify...... Mobile SL3 Mobile Type SL3 are all types of HP BB5 SL2, whether using single or dual engine processor, using RAP3G or Rapido, if phone has PM120 area or / and have a protected area PM308 and also protection against firmware so that in general the various tools or software improvement on the market today can not do Rebuilt Simlock data and key data on handpone simlock this category. Tipe2 Mobile Nokia SL3: * RM-352 3600s? MCU SW 56.26 * 5310 RM-303? MCU SW 58.58, 59.42 MCU SW. Raps V3.01 * 6300 RM-217? MCU SW 57.20 * 6500C RM-265? MCU SW 59.45 RAP3GS V2.0 * RM-240 6500s? MCU SW 59.60 RAP3GS * 5130c RM-495 ALL-PA RAPS_V3.03 version According to information circulating among programmers and engineers that most tools or software on the market improvements have not been able to do against handphone2 UNLOCK process, because handphone2 PM308 has a protected area which can not be re-programmed (except for DM3? There may be a tool that others). Also Rebuild process Cert (ASK-RPL service) will not run perfectly or it can be said Not Supported? So if we have a case? Contact Service? simlock caused by a corrupt (in cell phones this type), do not rush to do ask2rpl service because there are no tools / software improvements that can improve all of the certificates are perfectly / properly 100% .. Video Tutorials Contact'Service-5130c RM495 which often caused because security'failed Code:http://www.ziddu.com/download/872357...moved.rar.**** 05.08.2010 - MT Box Nokia - MTB NK 2.35.3 SL3 What's new in MTB NK v2.35.3 SL3: Added "SL3 Bforce compute" tab There is 3 buttons in SL3 Bforce tab: Read, Update and Write: * Read - Read phone and send data to SL3 server * Update - Check how many time need wait for code * Write - Enter unlock code directly to phone - No need to enter code manually Supported ROOT_KEY_HASH ( RAP ) for unlock: * 38F312750F686F9FC9B1B3778774A195 * 9A28E119033B91D14D22838C86D0D53C * 9DDBFCFE6E73CED7D8C6268C8EB85723 * A5404AE83A594ECADEE532F0C236BFA6 * BAF3A9C3DBFA8454937DB77F2B8852B1 * CAEEBB65D3C48E6DC73B49DC5063A2EE * E9EFF4BFAA5393217CA6B17755FC3E14 * F2D76DFAFD66C7F195F278417DF05888 * F682624FFB08F6D955DBE7D9C0485084 * FCB5C510AF7F09F313D9BDE85A707CC0 Phone model does not mater, just check ROOT_KEY_HASH and Do It How to check ROOT KEY HASH: * Start MTB NK v2.35.3 SL3 and press OK button How to install and use latest MTB NK software: * Download and install MTB NK v2.35.3 SL3 * Install MTB_NKgtr2_353sl3b to MT Box installation folder: Program files/GriffinTeam/MT box * Download MT Box update tool v3.18 * Start MT Box update tool v3.18 from ( c:\Program Files\GriffinTeam\MT-Box\) and update your box. * Run MTB_NKgtr2_353sl3b * In server tab click on Save button and add: User name: boxlogin Password: boxlogin * Go to SL3 Bforce compute tab * Connect phone to FBUS cable * Press Read button in SL3 Bforce tab Price per phone is 80 MT Box credits What's new on SL3 server side: We optimize our SL3 unlock servers, so now we can allow access to MT Box customers automatically. All customers who have 1000 and more MT Box credits have automatically enabled SL3 server access. No need more to fill the form and wait for SL3 server access. How to check does your SL3 access is enabled: * Start MT Box update tool v3.18 * Connect MT Box to USB * Press Info button * The last info in MT tool is your credit status - BOX Credits Available: ***x * If have more then 1000 credits available you are ready to start We have added average time info on our home page and support forum. So now you can know how many time you will wait for code without to upload phone to SL3 server. The time changes non stop, because for some phones server need 2 minutes but for some 1 hour. Why GT SL3 server? * There is not hidden calculation time, you can check it before upload phone * The calculation time cant be longer then server shows you in moment you upload phone. Only can be less then this! * You can always cancel the calculation for any phone you have uploaded and get your credits back * Servers are up and running 24 hours per day, * There is no server downtime * We constantly extend and optimize our SL3 data center * Because maximum time to calculate code is 01:11:41 ( 1 hour : 11 minutes : 41 seconds) BR Mudassar Mughal 007 |
The Following 7 Users Say Thank You to ..::007::.. For This Useful Post: |
Full Flash 5130 V05.61 | nokia_flash | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-03-2011 15:38 |
how to unlock 5130 | accelr8 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-24-2010 17:52 |
NOKIA 5130 Soft 5.71??? | Erik | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-19-2000 17:29 |
5130 V.61 | bzegarac | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-20-2000 11:37 |
5130 5190 6190 | MGG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-03-2000 20:36 |
