Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 09-30-2010, 21:31   #1 (permalink)
Member: 857234
Sonork: Dc
Thanks Meter: 196
5130c rm-495 npc data invalid
I received today with this problem .
can't do another job ( write pm/rpl , Repair SD etc... except check with software .
seen log and advice me for solved .
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 08C0011683657D562A7310CB6D7CBC660FBAC476
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Original Imei: Empty
Original Product code: Empty
NPC_DATA invalid !
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.96 20-05-10 RM-495 (c) Nokia
Imei plain: 12345610654321-?
Product Code: 0571584
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
ways for solved
The Following User Says Thank You to djibrilcoulibal For This Useful Post:
Old 12-22-2010, 16:23   #2 (permalink)
Member: 318237
Thanks Meter: 4
mxkey not supported yet,I to tink.
my problem is too,5130c
buy rpl or waiting mxkey team to free sl3 rpl
Old 12-22-2010, 19:01   #3 (permalink)
kaleem munir's Avatar
Member: 720201
Sonork: 100.0000000
Thanks Meter: 642
no solution bcz its sl3
Old 12-22-2010, 19:04   #4 (permalink)
paulo pessoa's Avatar
Member: 1474113
Sonork: 100.1604217
Thanks Meter: 227
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC_DATA invalid !
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
ways for solved
Ah no possibilities to solve this problem because the imei is damaged only by generating a Rpl for the same date Sl blighter unresolved in time dear!
Old 05-27-2011, 18:12   #5 (permalink)
Member: 1451292
bro i have same problem can there is any solution for it
Old 06-05-2011, 05:21   #6 (permalink)
Member: 1575037
SW Version: V 07.97 13-09-10 RM-495 (c) Nokia
Product Code: 0577794
Battery voltage: 4760 mV, current: 55 mA
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Old 11-30-2011, 05:28   #7 (permalink)
anujc143's Avatar
Member: 1550704
Sonork: 100.1644808
Thanks Meter: 230
NPC_DATA invalid !
anny solution bro
Old 11-30-2011, 05:32   #8 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 329
Originally Posted by anujc143 View Post
NPC_DATA invalid !
anny solution bro
Mate NPC invalid means RPL is corrupted and the only solution is buying RPL.
WBR
Old 12-01-2011, 06:47   #9 (permalink)
Member: 714710
Sonork: offline
Thanks Meter: 983
buy rpl ...........................first and last solution
Old 12-01-2011, 08:57   #10 (permalink)
logicmobile's Avatar
Member: 1016569
Thanks Meter: 206
problem
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC_DATA invalid !
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
ways for solved
brother
i have 8 pcs nokia 5130c related to same problem but
no solution yet .
Old 12-01-2011, 10:50   #11 (permalink)
rizwankhan8670's Avatar
Member: 1497980
Thanks Meter: 1,181
[QUOTE=logicmobile;7942550]
brother
no solution yet .
[/QU
bro you buy rpl no other solution
Data cable Aldrin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:06
cellular data suite kabel vingis Main Sales Section 0 11-25-1999 19:18
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 Nk_Cable Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-10-1999 10:08
Cellular Data Suite Cables avaliable !!! vingis Main Sales Section 0 11-02-1999 17:35
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 nk.cable Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-14-1999 16:33
Page generated in 0.34985 seconds with 8 queries
