5130C Super DONGLE KEY DAMAGED But FULL RPL OK BACKUP EXIT Dear ALL, one month ago i received 5130c with blinking problem so i flash phone after that phone will be ok.. so i made full backup with mx-key (full rpl + full pm) After month again i received that set in contact service problem but interesting thing is that super dongle key missing. So I write Full ok Backup including pm via mx-key but after write still same condition This phone have protected pm 308 ..... so during restoring pm 308 ..it unable to write pm 308. can we write pm 308 @ SL3 Phone via cross flashing ???? Tomorrow i will post you all logs of this ALL Suggestion is appreciate able ...;) Rgds bluffmaster |
You can do the cross flash using the 5310 firmware.. Just be carefull BR Alex |
Hi, Brother I Have Full ok Backup(pm308) ... but why i am not able to restore??? Rgds bluffmaster |
AFAIK, 308 field cannot be written (protected), you can fix that via logs by UB or Mtbox :) then write RPL back via MXKEY :) |
2: write pm backup area 308 3: flash back using 5130c 4: pmm auth and skip area 308 with mxkey 5: just be carefull,,,,, |
- Do selftest and check If (ST_Simlock_Failed) means you will have to load simlock_data and simlock_data_key. As you know simlock cannot be written in PA_SL3 except tucsan rpl and mx-key to upload. - If (ST_Security_Failed) means you will have to load superdongel data. You can repair this data using MT,UB. It can be written in PA_SL3 using normal rpl. - If both are damaged so you have to buy Nokia tucsan rpl. BR, Ali |
you save then, since your location says you in the right place. ;) NO Need MT or UB or a single dime for your case :p |
