Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 12-06-2009, 15:45   #1 (permalink)
Member: 248182
Thanks Meter: 785
5130C Super DONGLE KEY DAMAGED But FULL RPL OK BACKUP EXIT
Dear ALL,
one month ago i received 5130c with blinking problem so i flash phone after that phone will be ok.. so i made full backup with mx-key (full rpl + full pm)
After month again i received that set in contact service problem but interesting thing is that super dongle key missing.
So I write Full ok Backup including pm via mx-key but after write still same condition
This phone have protected pm 308 ..... so during restoring pm 308 ..it unable to write pm 308.
can we write pm 308 @ SL3 Phone via cross flashing ????
Tomorrow i will post you all logs of this
ALL Suggestion is appreciate able ...
Rgds
bluffmaster
Old 12-07-2009, 02:30   #2 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,004
You can do the cross flash using the 5310 firmware..
Just be carefull
Alex
Old 12-07-2009, 04:55   #3 (permalink)
Member: 248182
Thanks Meter: 785
Just be carefull
Alex
Hi,
Brother I Have Full ok Backup(pm308) ... but why i am not able to restore???
Rgds
bluffmaster
Old 12-07-2009, 05:01   #4 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
AFAIK, 308 field cannot be written (protected), you can fix that via logs by UB or Mtbox
then write RPL back via MXKEY
Old 12-07-2009, 05:47   #5 (permalink)
Member: 1175373
Originally Posted by bluffmaster View Post
Hi,
Rgds
bluffmaster
step 1: you can do the cross flash using 5310 firmware
2: write pm backup area 308
3: flash back using 5130c
4: pmm auth and skip area 308 with mxkey
5: just be carefull,,,,,
The Following User Says Thank You to vanzphonerepair For This Useful Post:
Old 12-07-2009, 11:35   #6 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,581
Dear ALL,
Rgds
bluffmaster
Hi,
- Do selftest and check If (ST_Simlock_Failed) means you will have to load simlock_data and simlock_data_key. As you know simlock cannot be written in PA_SL3 except tucsan rpl and mx-key to upload.
- If (ST_Security_Failed) means you will have to load superdongel data. You can repair this data using MT,UB. It can be written in PA_SL3 using normal rpl.
- If both are damaged so you have to buy Nokia tucsan rpl.
BR, Ali
Old 12-09-2009, 16:04   #7 (permalink)
Chevka's Avatar
Member: 82106
Thanks Meter: 1,208
Dear ALL,
Rgds
bluffmaster
you save then, since your location says you in the right place.
NO Need MT or UB or a single dime for your case
Old 12-09-2009, 16:12   #8 (permalink)
prince_arsalan's Avatar
Member: 618626
Sonork: 100.1592779
Thanks Meter: 61
So Can You Explain How To Restore Backup In 5130.............
5130c super dongle invalid pallumobile MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 02-16-2010 09:43
mx key super dongle key sucessfull video it is ok .::VENUGOPAL::. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-13-2010 05:51
e63 full backup but unable to update super dongle key bluffmaster MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 10-26-2009 11:44
E63 full backup unable to restore super dongle key bluffmaster HTC CODE WORLDWIDE 0 10-26-2009 09:00
Page generated in 0.34684 seconds with 8 queries
