Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 04-30-2009, 15:51   #1 (permalink)
Member: 884054
Thanks Meter: 27
5310b after flash "contact service"
MCU SW : V 09.42 07-11-08 RM-304 (c) Nokia
PPM SW : V 09.42 07-11-08 RM-303 (c) Nokia A
Prd.Code: 0561210
Bpr.Code: 0544851
Prod.Sn : RGK341036
HW Vers : 3502
EM VILMA: 15
EM BETTY: 22
RFIC Ver: 064c0609
DSP Vers: ICPR71_08w30
LCD Type: SEIKO
IMEI : 123456-10-654321-?
SL Serv : SIMLOCK SERVER
SL Conf : 000-00-00000000000
SL Stat : 0141196300000000
SL Count: 00 00
Provider: Not Found
1ST BOOT : C0,07 [Rm-304] [2.0.8.0]
RAPx ID : 000000010000022600010006010C192101013000
EM 1 ID : 00000295
EM 2 ID : 00000B22
RAPx PBID : 2B50010AEC990254879A0478065F7875D6D45107
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 1.30.0
CMT FLID0 : 00EC220C-00008921, Sam K8F1215ETM
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5
CMT KSIG0 : 3E96DE4212587183E5E16BB2C79692A53C19875D
CMT VPP : Internal
DUAL LINE : False
CMT ALG Boot OK
Using Internal VPP
CER FLASH ERASE OK, Time: 00:00
DUAL LINE : False
ERR: CER FLASH WRITE C_BLK: F372000000F172, Time: 00:15
CMT NPC Certificate Write Failed
the error in the message at wr cert ( npcc certificate)
plz help me thankssssssssssssssssss
Old 04-30-2009, 16:03   #2 (permalink)
Member: 884054
Thanks Meter: 27
I restore 308 ,pm and rd cert
plz help me
Old 04-30-2009, 18:06   #3 (permalink)
Member: 884054
Thanks Meter: 27
Thanks very much
I will be tested
Old 04-30-2009, 18:34   #4 (permalink)
Member: 457470
Thanks Meter: 159
your imei also gone write imei backup also and use dual line flashing
Old 04-30-2009, 18:52   #5 (permalink)
unlockcare.us's Avatar
Member: 343670
Sonork: N/A
Thanks Meter: 572
flash your fone with 5310b flash file. if u wanted to flash it with 5310 flash file u forgot to tickmark on downgrade box.thats why its happend.
Old 05-02-2009, 09:46   #6 (permalink)
Member: 884054
Thanks Meter: 27
i will try
thankssssssssssss
Old 05-02-2009, 11:54   #7 (permalink)
Member: 884054
Thanks Meter: 27
same the problem
MCU SW : V 07.01 23-05-08 RM-304 (c) Nokia
PPM SW : V 07.01 23-05-08 RM-303 (c) Nokia M1
Prd.Code: 0561210
Bpr.Code: 0544851
Prod.Sn : RGK341036
HW Vers : 3502
EM VILMA: 15
EM BETTY: 22
RFIC Ver: 064c0609
DSP Vers: ICPR71_08w10
LCD Type: SEIKO
SL Stat : 0144196600000000
SL Count: 00 00
Provider: Not Found
any person help me to solve this problem
Old 05-02-2009, 12:00   #8 (permalink)
Member: 884054
Thanks Meter: 27
my backup only by tornado
Old 05-02-2009, 12:08   #9 (permalink)
Member: 884054
Thanks Meter: 27
backup
If any damaged or error in this backup please correct or any solution
step by step
Old 05-02-2009, 12:23   #10 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
you flash with orijanel virjan it oll ok 10000000000%
Old 05-02-2009, 12:34   #11 (permalink)
tontonflach's Avatar
Member: 168513
Thanks Meter: 838
<a href="http://plugin.smileycentral.com/http%253A%252F%252Fwww.smileycentral.com%252F%253F partner%253DZSzeb008%255FZNxpt445YYDZ%2526i%253D23 %252F23%255F50%255F11%2526feat%253Dprof/page.html" target="_blank"><img src="http://smileys.smileycentral.com/cat/23/23_50_11.gif" alt="SmileyCentral.com" border="0"><img border="0" src="http://plugin.smileycentral.com/http%253A%252F%252Fimgfarm%252Ecom%252Fimages%252F nocache%252Ftr%252Ffw%252Fsmiley%252Fsocial%252Egi f%253Fi%253D23%252F23_50_11%2526uiv%253D3.0/image.gif"></a>
Nokia 1600 after flash "CONTACT SERVICE"" mobilplu Universalbox 16 08-12-2010 14:34
6610i After flash "Contac Service" NuengEve UFS2 + UFS3-Tornadoflasher 5 07-09-2005 14:47
Griffin flash "contact service" DanskUnlock Griffin 4 10-29-2003 07:43
Page generated in 0.18094 seconds with 9 queries
