04-04-2009, 17:55 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Hafizabad, Pakistan
Member: 269126 Status: Offline Sonork: 100.1616382 Thanks Meter: 370 | 5610d strange problem when unlock with zulea Searching for UFS box ... UFS box detected Box firmware version: 208 Searching for phone ... Phone found on FBUS interface Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-242 Version: V_04.81_22-11-07_RM-242_(c)_Nokia IMEI: 354850021549365 SP LOCK status: Config Key: 0000000000000000 Provider Key: 0000000000000000 Counters: 0/3, 0/10 Phone is Unlocked Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-242 Version: V_04.81_22-11-07_RM-242_(c)_Nokia IMEI: 354850021549365 SP LOCK status: Config Key: 0000000000000000 Provider Key: 0000000000000000 Counters: 0/3, 0/10 Phone is Unlocked Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-242_354850021549365_Unlocked_Keycnt_0_Fbuscnt_0__V _04.81_22-11-07_RM-242_(c)_Nokia__03_04_2009__15_05_29.bin PM308 backup OK BB5 FLASH bb5challenge ... ASIC ID: 000000010000022600010006010C192101003000 HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F CMT Boot Ready HELLO start JAF BB5Plus No TP by [c]Cinek started. ok Connecting to virtual server Credits: 20 Data recived. Err no (Jobs): 20120091 |
04-05-2009, 03:31 | #3 (permalink) | |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | The problem is phone has already SP Area courpted Quote:
B.R., kashi4gul | |
04-05-2009, 12:50 | #6 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 920362 Status: Offline Sonork: 1625931 Thanks Meter: 47 | dear you have to conver Config Key: 0000000000000000 Provider Key: 0000000000000000 into Config Key: FFFFFFFFFFFFF Provider Key: FFFFFFFFFFFFFF now you have to erase the phone useing rapido erase file but you should get back up RPL before make erase |
04-05-2009, 17:37 | #10 (permalink) |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | Nokia 6500-s not able to procedd for unlock I try to unlock 6500-s but It is doing same procedure. as ..PROBLEM is NOT ABLE TO READ ASIC ID:blank HASH: blank ROMID:blank CMT BOOT Ready then error : codes number comes I am using 5610d Cable Which cable else should be use 7 or 10 pins ? thanks B.R. |
04-06-2009, 10:37 | #11 (permalink) |
Member: 269126 Status: Offline Sonork: 100.1616382 Thanks Meter: 370 | Powering the phone... Reading... MCU SW version: V 08.30 03-07-08 RM-242 (c) Nokia HW version: 1000 PCI version: RFIC version: 17141715 DSP version: ICPR71_08w22 LCD version: SHARP PPM version: V 08.30 03-07-08 RM-242 (c) Nokia V Retu version: 15 Tahvo version: 22 Content Pack version: Content: v_no_yahoo V 08.30 03-07-08 RM-242 (c) Nokia Production serial number: CEJ531002 Product code: 0555379 Module code: 0203378 Basic production code: 0515121 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 354850021549365 IMEI spare to net: 3A 45 58 00 12 45 39 06 IMEI SV to net: 33 45 58 00 12 45 39 56 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-242.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0555379 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-242\ Searching for default location of ini... Checking path: \Products\RM-242\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-242\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! |
04-09-2009, 10:52 | #12 (permalink) |
Member: 269126 Status: Offline Sonork: 100.1616382 Thanks Meter: 370 | zulea killed my cell phone,,,,,,,,,,,,,,,,,,,,,im not able to restore back its failed wht i do?how i can repair SL zone for 5610d |
04-13-2009, 14:22 | #13 (permalink) |
Member: 269126 Status: Offline Sonork: 100.1616382 Thanks Meter: 370 | 5610d Powering the phone... Reading... MCU SW version: V 08.30 03-07-08 RM-242 (c) Nokia HW version: 1000 PCI version: RFIC version: 17141715 DSP version: ICPR71_08w22 LCD version: SHARP PPM version: V 08.30 03-07-08 RM-242 (c) Nokia V Retu version: 15 Tahvo version: 22 Content Pack version: Content: v_no_yahoo V 08.30 03-07-08 RM-242 (c) Nokia Production serial number: CEJ531002 Product code: 0555379 Module code: 0203378 Basic production code: 0515121 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 354850021549365 IMEI spare to net: 3A 45 58 00 12 45 39 06 IMEI SV to net: 33 45 58 00 12 45 39 56 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-242.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0555379 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-242\ Searching for default location of ini... Checking path: \Products\RM-242\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-242\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done |
04-13-2009, 15:18 | #14 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Murcia,Spain Age: 44
Member: 116918 Status: Offline Sonork: 100.1590386 Thanks Meter: 559 | Write your backup full PM using JAF Customer Care and SX4 Auth and phone should return to normal state locked but working. BR MAttYB |
6300 strange problem while unlocking with BB5 box | kushstha | BB5BOX | 5 | 10-07-2007 23:33 |
6300 strange problem while unlocking with BB5 Box | kushstha | Nokia Base Band 5 ( BB-5 ) | 4 | 10-05-2007 04:29 |
D520 strange problem when unlocking | the new | Trident/AGERE Platform | 2 | 08-09-2006 14:24 |
Z520i strange problem after unlock with cruiser | danned | Cruiser Suite | 8 | 01-08-2006 18:49 |
strange problem when unlock treo 600 | DeDo Gsm1911 | PalmOS /HP and others | 0 | 03-17-2005 13:36 |
