08-04-2012, 15:35 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Amriswil Age: 41
Member: 99073 Status: Offline Thanks Meter: 91 | 5700 cyclone problem ?? Custom loader running OK! Working... [LdrDebug] RAPxx CommonBoot Startup... V1.06 (c) KarwosLabs 2011 [LdrDebug] --- Debug Channel --- [LdrDebug] Target: RAPIDO CPU [LdrDebug] ARM MCU ID Ret: 0x4107B366 [LdrDebug] ReadRomID Ret: 0xF2C6EBAD [LdrDebug] ReadSysReg(0) Ret: 0x55555555 [LdrDebug] ReadSysReg(1) Ret: 0xAAAAAAAA [LdrDebug] ReadSysReg(2) Ret: 0x00000001 [LdrDebug] ReadSysReg(3) Ret: 0x00000226 [LdrDebug] ReadSysReg(4) Ret: 0x00010006 [LdrDebug] ReadSysReg(5) Ret: 0x0C00F00F [LdrDebug] ReadSysReg(6) Ret: 0x48005365 [LdrDebug] ReadSysReg(7) Ret: 0x00000000 [LdrDebug] ReadSysReg(8) Ret: 0x7D500000 [LdrDebug] ReadSysReg(9) Ret: 0x400C1921 [LdrDebug] ReadSysReg(10) Ret: 0x01011103 [LdrDebug] ReadSysReg(11) Ret: 0x0000000A [LdrDebug] ReadSysReg(12) Ret: 0x00000000 [LdrDebug] ReadSysReg(13) Ret: 0x55555555 [LdrDebug] ReadSysReg(14) Ret: 0x55555555 [LdrDebug] ReadSysReg(15) Ret: 0x55555555 [LdrDebug] ReadSysReg(16) Ret: 0x55555555 [LdrDebug] Keys Copied Neither CYC file and exists or failed to read it from phone (Failed to Read Die ID (1)! Please send LdrDebug information to developer.) BB5 Unlock Failed -> Failed to obtain Phone Unique Data Why this appends |
08-04-2012, 17:19 | #2 (permalink) |
Member: 99073 Status: Offline Thanks Meter: 91 | Started Phone Security Analysis... MCU Version V 03.29 MCU Date 10-05-07 Product RM-230 (Nokia 5700) Manufacturer (c) Nokia IMEI 353964012700621 Mastercode 4452755112 Reading Security Block... Security block OK and saved to "RM-230_353964012700621_04-08-2012_171806.SecurityBlock.PM" Step 1 : Testing SIMLOCK -- SIMLOCK PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. -- SIMLOCK PROBLEM -- Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) Additionaly, Checking HWC/CCC Certs... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101011103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0FF0000C6553005874357303E6EC18C67EFC04EA CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_BOOT_ROM_CRC: F2C6EBAD CMT_SECURE_ROM_CRC: C86E6189 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC003000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0030 (Samsung), Size: 128MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 3D66090E94F3701646DA91CCD35BBAC22E5CBF73 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits HWC Looks OK! CCC Looks OK! Restarting MCU... -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block WARNING: "0FF0000C6553005874357303E6EC18C67EFC04EA.C000130E " Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101011103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0FF0000C6553005874357303E6EC18C67EFC04EA CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_BOOT_ROM_CRC: F2C6EBAD CMT_SECURE_ROM_CRC: C86E6189 CMT Ready! New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC003000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Sending Auxiliary Loader... Auxiliary Loader Sent! If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs Custom loader running OK! Working... [LdrDebug] RAPxx CommonBoot Startup... V1.06 (c) KarwosLabs 2011 [LdrDebug] --- Debug Channel --- [LdrDebug] Target: RAPIDO CPU [LdrDebug] ARM MCU ID Ret: 0x4107B366 [LdrDebug] ReadRomID Ret: 0xF2C6EBAD [LdrDebug] ReadSysReg(0) Ret: 0x55555555 [LdrDebug] ReadSysReg(1) Ret: 0xAAAAAAAA [LdrDebug] ReadSysReg(2) Ret: 0x00000001 [LdrDebug] ReadSysReg(3) Ret: 0x00000226 [LdrDebug] ReadSysReg(4) Ret: 0x00010006 [LdrDebug] ReadSysReg(5) Ret: 0x0C00F00F [LdrDebug] ReadSysReg(6) Ret: 0x48005365 [LdrDebug] ReadSysReg(7) Ret: 0x00000000 [LdrDebug] ReadSysReg(8) Ret: 0x7D500000 [LdrDebug] ReadSysReg(9) Ret: 0x400C1921 [LdrDebug] ReadSysReg(10) Ret: 0x01011103 [LdrDebug] ReadSysReg(11) Ret: 0x0000000A [LdrDebug] ReadSysReg(12) Ret: 0x00000000 [LdrDebug] ReadSysReg(13) Ret: 0x55555555 [LdrDebug] ReadSysReg(14) Ret: 0x55555555 [LdrDebug] ReadSysReg(15) Ret: 0x55555555 [LdrDebug] ReadSysReg(16) Ret: 0x55555555 [LdrDebug] Keys Copied Neither CYC file and exists or failed to read it from phone (Failed to Read Die ID (1)! Please send LdrDebug information to developer.) Analyze Security Error -> Failed to obtain Phone Unique Data |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
