06-11-2011, 03:15 | #1 (permalink) |
Junior Member Join Date: Nov 2006
Member: 397088 Status: Offline Thanks Meter: 0 | 5800 dead after downgrade But the result is my display is kind of garbage Then I downgrade it to v20 using jaf and phoenix but it only diplays nokia then shuts down... Here is the log of jaf JAF version 1.98.62 Detected PKEY: 90009699 Card life counter: 99.99% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.1.36.0 Changing mode...Done! Changing mode...Done! Changing mode...Done! Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-356\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012_prd.core.C00 PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012_prd.rofs2.V11 CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012_C01_prd.rofs3.fpsx APE Variant file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012.udaerase.fpsx Languages in ppm: English,Arabic,French Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found No write data, skiping write... Sending RAW loader... Using 007.016.022 Elf2flash 08.37.001 CMT RAW loader... Sending RAW Loader... ....................Loader Sent! Stage 2 starting..............Phone prepared OK! Waiting for the phone to boot... Searching for phone... Status byte: 8000 Selecting CMT flash... Result: 0000 Phone is in flash mode... CMT blocks: 473, APE blocks: 0 Erasing cmt... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012_prd.core.C00... Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000 Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000 Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000 Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000 Erasing cmt zone 00D60000 - 09E5FFFF ... Erase result: 0000 Partition result: 0014 Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012_prd.rofs2.V11... Erasing cmt zone 06560000 - 0915FFFF ... Erase result: 0000 Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012_C01_prd.rofs3.fpsx... Erasing cmt zone 09160000 - 09E5FFFF ... Erase result: 0000 Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012.udaerase.fpsx... Erasing cmt zone 09E60000 - 0F71FFFF ... Erase result: 0000 Send CMT CFG... Writing cmt... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012_prd.core.C00... Sending CMT HASH for ADA Sending CMT HASH for KEYS Sending CMT HASH for PRIMAPP Sending CMT HASH for RAP3NAND Sending CMT HASH for PASUBTOC cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... Sending CMT HASH for SOS*UPDAPP Sending CMT HASH for SOS*ENO Sending CMT HASH for SOS*DSP0 Sending CMT HASH for SOS*ISASW Sending CMT HASH for SOS+CORE Sending CMT HASH for SOS+ROFS1 Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012_prd.rofs2.V11... Sending CMT HASH for SOS+ROFS2 Write result 27: 1701 Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012_C01_prd.rofs3.fpsx... Sending CMT HASH for SOS+ROFS3 Write result 27: 1701 Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_20.0.012.udaerase.fpsx... No write data, skiping write... Rebooting... Finishing CMT session... Restarting CMT... Pooling phone... MCUSW: V ICPR72_09w02.3 26-01-09 RM-356 (c) Nokia APESW: V 20.0.012 VariantSW: V 20.0.012 Prodcode: 0559408 Setting test mode... Failed! Aborting! Done! |
5110 v 6.0 after unlocking problem with net | cole | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-10-2001 16:11 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
