Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 08-15-2006, 10:31   #1 (permalink)
Member: 90869
Thanks Meter: 3
6280 UFS-3 tornado - ufs suite 3.01.00 - dctx2.01.00
I try to flash N6280 with ufs-3 with HWK, vpp adapter, UFS Suite 3.01.00, DCTx2.01.00...
On the phone V3.36, I tried only PPM, new sw 3.81, no success, always this screen:
1st BOOT : C0,07
RAPx ID : 000000010000022600010006010C192101003000
EM 1 ID : 00000232
EM 2 ID : 00000352
RAPx PBID : 15D001059D6A0050DFA7BE755DF3291199E88440
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 273F6D55DFAAF68F
CMT 1st Boot Ok
CMT 2nd Bt: RAP3Gv3_2nd.fg, Ver: 1.9.2
00000000: 02 00 00 00 00 F1 72 ......r
ERR: CMT 2nd Boot Resp: CERT Mismatch
Process Failed, Repowering Mobile
Local mode, test mode, info no problem.
Any Idea?
Thanks
Old 08-15-2006, 10:39   #2 (permalink)
Member: 71603
Thanks Meter: 31
The same me with 6680 and N-Box+HWK.????
Old 08-15-2006, 11:32   #3 (permalink)
Crazy Poster
Member: 316613
Try connect tornado/nbox to another usb port or try in another computer.
Turn off Firewall - in my case, when I've firewall ON , DCTxBB5 go crazy.
If this not help, try download and use DCTxBB5 v1.4e
Pins out are ok? Cable are ok? Tried with other phones?
Old 08-15-2006, 15:26   #4 (permalink)
Member: 45351
Thanks Meter: 2
Flash erase file first before flashing with normal flashfiles.
Old 08-15-2006, 16:02   #5 (permalink)
Member: 90869
Thanks Meter: 3
If you read carefully, cannot flash with anything, because on 2nd boot error message.
That is the point, flashing not started.
Old 08-16-2006, 14:08   #6 (permalink)
Member: 90869
Thanks Meter: 3
Ok, I tried a desktop pc instead of my laptop, so flashing started. But just erase from sectors, than it is the same.
Here:
1st BOOT : C0,07
EM 1 ID : 00000232
EM 2 ID : 00000352
RAPx MODE : 00
CMT 1st Boot Ok
CMT FLID0 : 00EC22FE-00000121, Sam K5X5629ATM
CMT FLCNT : 000000000000000000000000000000000000
CMT 2nd Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.9.3
CMT Alg Boot OK
Erase Area: CMT 0x00000000-000006BF
Erase Area: CMT 0x000006C0-0000FFFF
Erase Area: CMT 0x00020000-0007FFFF
Erase Area: CMT 0x00080000-000DFFFF
Erase Area: CMT 0x00200000-0037FFFF
Erase Area: CMT 0x00380000-011DDFFF
Erase Area: CMT 0x011DE000-011DEFFF
Erase Area: CMT 0x011DF000-011DFFFF
Erase Area: CMT 0x00100000-001FFFFF
What does it mean?
It was a working phone, Hunchison 3G Austria, so Drei, but just I wanted another language pack.
This snapshot came, when I tried V3.81, first I tried 3.36 only ppm, but the same, erasing ok, but after stop.
Old 08-16-2006, 14:45   #7 (permalink)
Member: 90869
Thanks Meter: 3
Problem solved, the VPP adapter was the problem. Without this flashing was super.
Old 08-30-2006, 13:19   #8 (permalink)
XHouser's Avatar
Member: 151737
Sonork: 100.1595988
Thanks Meter: 91
i have problem too with 6280 vrs 3.81 . 1st boot is ok but 2nd boot err....
Please i need help urgently ... i use slow and Xslow speed and VPP 3 ,5 and 9Volt
Old 09-09-2006, 17:03   #9 (permalink)
Member: 103794
just remove the VPP adapter.
Old 09-10-2006, 08:13   #10 (permalink)
Member: 303799
Sonork: inside outside
Thanks Meter: 59
hi where is this vpp adapter located sir?can you give us a view?thanks in advance
Old 09-10-2006, 10:40   #11 (permalink)
Member: 90869
Thanks Meter: 3
VPP adapter is an extended cable connected to UFS-3 box or other, so, it is "located" between your box and your cable to the phone. It has an RJ45 connection, BUT you dont need it, that is the point !
Old 09-13-2006, 12:18   #12 (permalink)
malek45's Avatar
Member: 32529
Thanks Meter: 23
u must use the cable without batterie
and a simple precaution ....
u dont use the usb cable when u program
i have 6280 die with a same solution
Old 11-12-2010, 00:55   #13 (permalink)
Member: 541680
sir i have ufs3 tornado but this is a clone so give me direct link to download ufs suite 3.01.000
Old 11-12-2010, 00:59   #14 (permalink)
Member: 541680
Sir i have ufs3 clone version so please give direct link for ufs suite 3.01 or 3.02 etc
UFS-3 Tornado + HWK by Sarasoft vs UFS-4 Tornado babaki UFS2 + UFS3-Tornadoflasher 18 11-03-2017 06:17
UFS SUITE 3.3 urgently need tarikalikhan UFS2 + UFS3-Tornadoflasher 12 10-19-2011 09:20
6280 flashing with UFS-3 tornado - snapshots shimano1234 UFS2 + UFS3-Tornadoflasher 11 03-19-2007 17:28
HELP! when connect UFS-3 Blue with Hwk with UFS Suite 3.0 mk21 UFS2 + UFS3-Tornadoflasher 0 08-22-2006 12:32
You need trusted seller ? UFS-3 Tornado, RPL service, Griffin, Sagem, Philips logs . legija Main Sales Section 0 03-09-2004 21:11
Page generated in 0.36526 seconds with 9 queries
