06-21-2008, 12:52 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 14047 Status: Offline Thanks Meter: 166 | 6288 unlocked but not unlocked Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 500 miliseconds Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 02 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 0000000000000000 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull when i read fone after unlock get this ???? Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: 355547014065206 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Model/version NOT supported for FBUS counter reset. Please upgrade or downgrade! This model/version IS SUPPORTED for UNLOCK. |
06-21-2008, 13:15 | #2 (permalink) |
Freak Poster Join Date: May 2007
Member: 518708 Status: Offline Thanks Meter: 67 | i think that there is a problem in simlock and/or firmware. first write back backup of pm 308 (the earliest one) and then downgrade your phone, after this update it to latest version and try to unlock it again... hope this helps for you best regards edit: just have seen that this is my post number 100... ;-) |
The Following User Says Thank You to desteufelsbrut For This Useful Post: |
06-21-2008, 13:16 | #3 (permalink) |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# |
The Following User Says Thank You to SHOEB AHMED For This Useful Post: |
06-21-2008, 13:36 | #4 (permalink) |
Member: 14047 Status: Offline Thanks Meter: 166 | thanks guy yes firmware i thought that i will update to newsest if bb5 box suppotrs it that s no updates for soooooooo long its the end for that box i think and cant try code 10 cose the guy who brought it to me to unlock already enter codes 3 times |
06-21-2008, 22:44 | #5 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: Earth
Member: 426389 Status: Offline Thanks Meter: 2,356 | Quote:
You can download full size image from rapidshare: http://rapidshare.com/files/12410032...88_1_.jpg.html BR | |
for me it show phone unlocked but not unlocked | mamepap | PolarBox 3 | 0 | 10-27-2008 11:31 |
samsung c266 phone unlocked but not unlocked | Pilarense | PolarBox 3 | 4 | 03-24-2008 16:50 |
lg-kg115 unlock but not unlocked | Dafageni | FuriousGold | 1 | 05-02-2007 08:49 |
nokia 1600 unlocked but not unlocked!!!!!!!! | benarmand | Nokia Digital Core Technology 4 ( DCT-4 ) | 20 | 07-05-2006 06:56 |
help phone says unlocked but not unlocked | taariqmajid | Redbox | 0 | 09-27-2005 15:57 |
