Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 07-17-2009, 16:54   #1 (permalink)
Member: 557956
6300 dead, help
a try to flash, jaf log say via fbus
AF version 1.98.62
Detected PKEY: 9000C796
Card life counter: 99.99%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Archivos de programa\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Archivos de programa\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.16.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Archivos de programa\Nokia\Phoenix\Products\RM-222\
Searching for default location of ini...
Checking path: C:\Archivos de programa\Archivos comunes\Nokia\DataPackage\Products\RM-222\
Scanning ini files...
MCU Flash file: C:\Archivos de programa\Nokia\Phoenix\Products\RM-222\rm217__05.00.mcusw
PPM Flash file: C:\Archivos de programa\Nokia\Phoenix\Products\RM-222\rm217__05.00.ppm_l
CNT Flash file: C:\Archivos de programa\Nokia\Phoenix\Products\RM-222\rm217__05.00.image_l_movca
Languages in ppm: English,Spanish,French,Portuguese
Backing up CRT data...
Setting FLASH MODE
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 002F0001 <=> SPANSION -> 72NS256N
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Archivos de programa\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
VARIANT CRT empty, skip save...
Reading CMT CCC certificate...
Reading CMT HWC certificate...
Saved to C:\Archivos de programa\ODEON\JAF\ProgData\35482701858271_CRT_bac kup_1138177.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Setting local mode...
Reading IMEI...
Failed! Aborting!
Failed to backup LCK...
Manual mode selected, version can't be checked!
Booting phone...
Error sync the phone...
Booting phone...
a try via usb dead, jaf log
JAF version 1.98.62
Detected PKEY: 9000BE34
Backing up CRT...
Detected P-KEY: 9000BE34
Init usb communication...
Reading IMEI...
Failed! Aborting!
Failed to backup CRT...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 02.33.000 RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... ..................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Phone rebooted but not in flash mode...
Old 07-17-2009, 19:59   #2 (permalink)
mobile-phone-service's Avatar
Member: 599385
Sonork: 100.1583205
what software version was in your phone?And whit what version did you try to flash?
Old 07-17-2009, 20:17   #3 (permalink)
octavyus's Avatar
Member: 242469
Exclamation
make with dead usb mode
use last firmware version
install last version of Nokia_Flashing_Cable_Driver
or you can use FBUS is better ins this cases
B.R
Old 07-17-2009, 21:13   #4 (permalink)
Member: 557956
try via usb but not jump me this error
Phone failed to boot in flash mode CMT...
I can not find the version that does not read, and choose the version that is 5.0 to flash,
any idea
Old 07-17-2009, 21:23   #5 (permalink)
Member: 599385
Sonork: 100.1583205
download from suport last software version and than try again.
Old 07-17-2009, 21:29   #6 (permalink)
sebha's Avatar
Member: 595700
Sonork: 100.1582336
flash wed higher version n change ur cable use 3110c cable if solve flash wed mt-box wed 10pin cable 100% ok
Old 07-17-2009, 23:43   #7 (permalink)
abdurrahimsagar's Avatar
Member: 734476
Sonork: 100.1604415
Please Flash HWK BOX 1000000000000% Work
Old 07-18-2009, 00:12   #8 (permalink)
Member: 557956
probe with cable and 3110c does not work with mt-box will not be possible in no paraguay, try to get someone who has HwK
thank you all and post results
Old 07-18-2009, 00:24   #9 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
your using old flash file try new or latest it would be much fine...
Old 07-18-2009, 15:19   #10 (permalink)
amirsaishi's Avatar
Member: 241938
flash with a higher version..
Old 07-18-2009, 17:18   #11 (permalink)
masum_sohel's Avatar
Member: 852543
just flash with higher firmwere 7.30 it will be ok
Old 07-18-2009, 18:24   #12 (permalink)
Member: 541592
RM-222 this not 6300 flash file , if your phone realy 6300 ,then you need flash with RM-217 last version 7.21 or high
Old 07-22-2009, 16:43   #13 (permalink)
Member: 557956
and handed the phone can not solve, I did everything they told me nothing but the same error, perhaps either a hardware problem, thank you very much for the help
nokia 6300 dead help me arifm_cools Nokia Hardware & Hardware-Repair Area 0 08-11-2009 12:40
6300 dead, pleas help! kadour83 Nokia Hardware & Hardware-Repair Area 1 03-12-2008 22:37
6300 dead after water damage pliiz help bighicham Nokia Hardware & Hardware-Repair Area 0 12-19-2007 12:31
Page generated in 1.47788 seconds with 11 queries
