04-02-2009, 20:42 | #1 (permalink) |
Freak Poster Join Date: Apr 2001 Location: greece , Athens , Kifisia Age: 45
Member: 4397 Status: Offline Thanks Meter: 3 | 6680 flashing Error I bought a nokia 6680 from england orange network and wanted to change to greek firmware. Well i used nss changed the product code and went to nokia center to flash it. Flashing stoped at some point with error (product code error.). Since then my phone does not power up. I connect it to pc and pv says unkonwn device. Any ideas? Pls urgent. Thank you. |
04-02-2009, 21:02 | #2 (permalink) |
Member: 4397 Status: Offline Thanks Meter: 3 | Here is responce from nss: JAF version 1.98.62 Detected PKEY: 90009699 Card life counter: 99.99% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 6.82.4.0 Changing mode...Done! Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-36\ Scanning for ini files... INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-36\RM36_4.050434_B5.C0R PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-36\RM36_4.050434_B5.vEU CNT Flash file: NONE APE Variant file: NONE Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Not found!!! Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Not found!!! Changing mode... Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... Done! Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Not found!!! Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Not found!!! Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Not found!!! Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Not found!!! |
04-03-2009, 07:59 | #7 (permalink) |
Member: 4397 Status: Offline Thanks Meter: 3 | Fbus cable in pop port or jtag port? And how to make fbus from straight usb dku2? Pcb sure ok cause phone was working fine. Thank you. |
6680 flash error, no power | sky178 | HWK | 1 | 10-12-2006 11:38 |
6680 flashing error | namra | Universalbox | 2 | 06-05-2005 21:41 |
