Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 11-30-2005, 10:11   #1 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 203
6680 FRONT CAMERA = Feature not Supported.
Hi Guys,
I ve got a 6680 which gives the ERROR = Feature not Supported. If you try to set on FRONT CAMERA.The back camera is working FINE.I tried to flash it but still the same problem.
Any idea???
Old 11-30-2005, 12:18   #2 (permalink)
Member: 195968
i can help
i had the same problem!!this is what u must do!first take out your memory card then use this code 2 format> *#7370# make sure your mem is not attached.then after phn resets try it but with out your mem card inside it should work!!!let me know what happens!
Old 11-30-2005, 16:40   #3 (permalink)
Member: 90377
Thanks Meter: 3
first try to format the mmc, if it doesn't work then reset the phone also
Old 01-17-2006, 23:21   #4 (permalink)
Tetouan Gsm's Avatar
Member: 190492
Sonork: 100.01010100
Thanks Meter: 187
i have a some problem i try to flash it but still same problem ...i think in hardware ....?? not software ..any solution i try in hard if i find it i post it good luck..
Old 01-19-2006, 16:34   #5 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 203
Deleted Deleted Deleted Deleted Deleted
Old 01-19-2006, 16:51   #6 (permalink)
Member: 190492
Thanks Meter: 187
Good Idea i format my memory card and i put it in my Phone then i format phone camera is good now ...thnx Man
Old 08-04-2006, 14:19   #7 (permalink)
Paki Mobile's Avatar
Member: 50106
Sonork: 100.109487
Thanks Meter: 209
i try but same not ok
Old 08-04-2006, 14:20   #8 (permalink)
Member: 50106
Sonork: 100.109487
Thanks Meter: 209
i try but same not ok ...............................
Old 08-07-2006, 09:28   #9 (permalink)
Member: 247864
I encountered the same problem with an n70, it seems dat the front camera is pressed to hard by the front housing thats why got hardware error.. usually this happens when use not original housings or the camera frame is dented into the camera.. try and make at least a bit gap between teh fronts camera and the lens cover on the housing..
Hope this helps..
Old 09-09-2006, 18:56   #10 (permalink)
Member: 332725
6680 front camera not supported
i have the same problem before .by the way what is the condition of your mobile before that is water damage or no.if not water damage check the pin contact on your camera ic arrange it .if not work try again .if not good re heat the camera ic and omap.
Old 09-11-2007, 18:20   #11 (permalink)
Muneer Ahmed's Avatar
Member: 60500
Thanks Meter: 2
its the problem of OMAP ic.....try to change the ic.....70% chance is that the phone will be ok
6120c front camera feature not support... 081372002070 Nokia Hardware & Hardware Repair 1 10-25-2013 09:11
6120 front cam feature not supported sanamsanam Nokia Hardware & Hardware Repair 2 12-04-2011 21:49
6680 front camera feature not supported HUM Nokia Hardware & Hardware Repair 1 01-14-2010 10:25
n6110 navigator front camera feature not support alex1123 Nokia Hardware & Hardware Repair 0 06-19-2009 19:10
6120 front cam feature not supported mian avais Nokia Base Band 5 ( BB-5 ) 2 06-26-2008 12:01
Page generated in 0.37472 seconds with 8 queries
