02-04-2010, 16:00 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: India
Member: 601200 Status: Offline Thanks Meter: 142 | 7210c security test failed I have 7210c with contact service. I write modified pm but still problem.pls help. Here is log....... Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11893, Date: 26-01-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 22B0001894F17C56E6C3576FCABE7EBE2DD68970 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 Original Imei: 3593100******* Original Product code: 0572571 Bluetooth ID: 0024048DC9CE Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35931002******-* Product Code: 0566806 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35931002******* Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to Jabir27 For This Useful Post: |
10-26-2010, 21:33 | #7 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Raiganj Age: 37
Member: 1175794 Status: Offline Thanks Meter: 186 | if u tired of this "security test failed" problem.. Now do a last try with my advice .. FIRST BACK UP ONLY NPC DATA 2ND RESET NPC DATA THIRD WRITE FULL MODIFIED PM 4TH RESTORE NPC FROM BACK UP 5TH REPAIR SD AND THE LAST MAGIC OPTION "RECOVER CERT"............. Just click "recover cert" option.. Because its works for me.... |
The Following User Says Thank You to n2roy For This Useful Post: |
01-21-2011, 10:10 | #9 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Mangalore India
Member: 1285436 Status: Offline Thanks Meter: 6 | Try it in Advance Turbo Flasher... Repair Super dongle... And SX4 PM auth 100% will solve the problem |
The Following User Says Thank You to NayanMangalore For This Useful Post: |
01-21-2011, 10:40 | #10 (permalink) |
No Life Poster Join Date: Jan 2011 Location: INDIA>GUJARAT
Member: 1497850 Status: Offline Sonork: 100.1601368 QQID:21952428 Thanks Meter: 1,575 | Try in mxkey super sd then write pm 1 and 309.... its work........ |
The Following User Says Thank You to idrish911 For This Useful Post: |
04-01-2011, 13:02 | #12 (permalink) |
Freak Poster Join Date: Oct 2010 Location: dimapur, nagaland
Member: 1416083 Status: Offline Sonork: 1640399 Thanks Meter: 16 | Final Solution 100% Sure 1. backup NPC 2. reset NPC 3. Write PM 1 and 309 Using SuperSDAuth 4. Write RPL 4. recover Certificate (At times it is not necessary ) |
7210c cs security test failed. | Triminity | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-15-2010 08:07 |
7210c Security Test failed yet now pls help me MXkey Team | asmanju08 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 30 | 02-11-2010 12:16 |
Success two security TEST failed but faile in one 5220 FAILE | khokonhajigonj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-09-2010 15:38 |
7210c CONTACT SAERVICE security test failed [ Solved ] | jermaineyork | Cyclonebox | 4 | 02-04-2010 06:35 |
7210c st security test failed, contact service? | shahinahmed007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 20 | 01-10-2010 06:40 |
