12-20-2010, 13:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Nepal
Member: 667126 Status: Offline Sonork: 100.1651201 Thanks Meter: 229 | All 5130 contac service solution....50%Hope That is because this phone have protected PM 308 that cannot be written in Local/Flash Mode condition...and because some other reason... First...Let See Some Fact... 1. In normal condition(Local/Flash Mode), we cannot write/modify this area PM 308... I did test using MXKey, try to write this PM 308....result failed...but this area not be corrupt/modified... its mean... in normal condition, even CPU cannot modify this area by its self.... (Some people told me, with some trick we can write this area) 2. In Normal condition (Local/Flash Mode), we can do write/modify RPL or Certificate... All of us know about this... that is why we can do Superdongle Repair... 3. PM Area 120 contain some Data SIMLOCK that have connection with PM area 308... this area(PM 120) have no protection from written...but will be syncronized.... or chek???...or analized by CPU using it certificate... that is just my opinion... i am not a programmer... So... Lets we make some analysis..... Refer to the fact number 1... in normal condition this PM 308 will not corrupt/modified forever...if hardware still have good condition... Then... the important question is... how can it corrupted as reported by many people here in gsmforum??? So... the answer is MAYBE NOT!!! Its not corrupted... but the others... other important PM value have corrupted.... And Offcourse...this condition cause MXKey Software or CPU???, read result like below... Quote: Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35932902982888-6 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! and because many people here doesnt have knowledge about this...(or i have wrong knowledge about this)........ if you ask for help in here with LOG like that... you will got answer like below... “not support right now brother... its SL3... wait for next update...” this make hard situation for product suporter to counter this....if my knowledge is right offcourse... But... in fact... you can fix that case... if you have backup important value... like full Valid PM and Valid Certifikat(RPL file)...at least Valid NPC(not sure about this) and doing right step... So... how in practice to solve that??? There are several ways... depend on the case.... Refer in my case.... My first log like this.... Quote: Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35932902982888-6 Product Code: 0578116 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! After some wrong operation at writing PM 1 and 309...come like below... Quote: Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35932902982888-6 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! Lucky... i do backup before... all important value.... But maybe cause i do wrong step.... it come like this below... Quote: Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35932902982888-6 Product Code: 0578116 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359329029828886 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF In fact... the phone live normally....All fitur are OK... amazing.... if you doing chek using JAF Software...all seems ok...security and simlock test will passed... and there is no Lock....all block open... but in MXKey BUS Chek or Scan.... simlock invalid..... even there are no lock and all block are open...as you can see... So... Is this some kind of Bug???????? I dont know... i am not a programmer dear........ So... what is the right step???... to make all have valid value.... Its easy... just ask to MXKey coder to fix the bug!!! LOL...... just kidding brothers.... The key is..... how to get the phone with beginning condition.... like log below... Quote: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! I think its possible....cause PM 308 cannot corrupt/modify...... Maybe someone here know how to resolve this.... If you know...please share...step by step.... After...this...maybe we can make SX4 Auth...and write PM 1 and 309 as normally.... By ANIL Bhetwal |
12-20-2010, 13:56 | #2 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | You know that is the cell phone company? Full PM I could write a similar one and then repair rpl and it is Tell me how I was .. Br Polaco |
03-02-2011, 00:42 | #3 (permalink) |
Major Poster Join Date: Jul 2009 Location: kolkata
Member: 1086792 Status: Offline Sonork: 1000.2 Thanks Meter: 10 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 20B0010335407E562E8F7851C0A95D90C2FD7D1E ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Original Imei: 35604003144282 Original Product code: 0577793 Bluetooth ID: 0026681FA3C4 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35604003144282-1 Product Code: 0577793 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! please manole help us we are waiting for your discustion |
03-02-2011, 00:43 | #4 (permalink) |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
