Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 02-18-2020, 17:54   #1 (permalink)
Member: 2835418
Thanks Meter: 6
Update your phones firmware yourself
This is an official Nokia program and should cause no harm to your phone if you follow this instructions properly.
Note: Some phones mightn't work if they are a network branded version, the program tells you if it can be updated before it does anything
Check here first to see if your phone has available software updates
Update via PC
Follow these step-by-step instructions to update your phone software, also known as firmware, for your Nokia phone.
Step 1/5: Get Started
Before you start, make sure you have met these requirements:
To install and run Nokia Software Updater application:
* PC with 1GHz or higher Pentium-compatible processor
* At least 256 MB of RAM (memory)
* Windows 2000 (SP4 or later) or Windows XP (SP1 or SP2)
* Administration rights on the PC while installing
* Internet connection
To connect your phone to a PC:
* Fully charged, compatible Nokia phone
* Compatible Nokia USB connection cable
* Compatible USB port on your PC
Step 2/5: Back-up data
Personal data such as contacts, photos and messages stored in the phone memory will be deleted during phone software update. It is strongly recommended that you backup this data to your memory card before updating your phone software.
To backup to your memory card:
1. select Tools > Memory from the main menu
2. select Options > Backup phone mem.
To restore info to phone memory:
2. select Options > Restore from card
Step 3/5: Download Nokia Software Updater
Download the Nokia Software Updater installation file below.
* If you are using Internet Explorer, select Run from the dialog box that appears.
* If you are using Firefox, select Save to disk and click OK.
Step 4/5: Install Nokia Software Updater
Click the Nokia Software Updater Setup icon (saved on your desktop or in another specified folder) to open the install wizard, which will guide you through the installation process.
After installing you can update your phone software.
Step 5/5: Check for firmware updates
Connect your phone to your PC via Nokia cable.
The Nokia Software Updater will guide you through the phone software update process.
Repeat Step 5 every time you check for phone software updates.
Page generated in 0.11996 seconds with 9 queries
