Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 12-01-2010, 16:09   #1 (permalink)
Member: 1393246
Thanks Meter: 22
e63-1 phone start-up failed contact the retailer
help e63-1 phone start-up failed contact the retailer
Phone Type: RM-437 (Nokia E63)
SW Version: V ICPR71_09w47.8 05-08-10 RM-437 (c) Nokia
Imei plain: 35683602129746-7
Product Code: 0568890
ApeCoreSw: 501.21.001
Language Pack:
- not available.
SIMLOCK invalid!
WMDRM_PD seems to be valid
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
Old 12-01-2010, 16:21   #2 (permalink)
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 2,563
THis is an SL3 phone! the solution is not possible at the moment!
Old 12-01-2010, 16:32   #3 (permalink)
Temporary banned !!
Member: 555091
Thanks Meter: 10
repaire SL and write 1+309 pm AND FULL FACTORY WITHE MXKEY
Old 12-01-2010, 16:40   #4 (permalink)
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 2,563
This solves the security test but not the simlock
Old 12-01-2010, 16:44   #5 (permalink)
Member: 1456766
Sonork: sami
u sea imei is ok so
use mx key update sp lock and then write 1+309 pm AND FULL FACTORY WITHE MXKEY
and post result,,,,,,,,,,,,,,,,,,,,
Old 12-01-2010, 19:16   #6 (permalink)
Member: 1393246
Thanks Meter: 22
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 356836021297467
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 12-02-2010, 03:20   #7 (permalink)
richiricherd's Avatar
Member: 594580
Thanks Meter: 157
Now just do PMM Auth or Super SD Auth if you did Repair SD then write good PM 1 and 309 all will be ok
Old 12-02-2010, 04:08   #8 (permalink)
Member: 495352
Sonork: 100.1589707
Thanks Meter: 70
Originally Posted by arfaoui608 View Post
phone type: rm-437 (nokia e63)
sw version: v icpr71_09w47.8 05-08-10 rm-437 (c) nokia
imei plain: 35683602129746-7
product code: 0568890
apecoresw: 501.21.001
language pack:
- not available.
simlock seems to be valid
superdongle_key seems to be valid
wmdrm_pd seems to be valid
simlock_test passed
security_test failed!
imei net: 356836021297467
version: simlock server
counter: 0/3, 0/10
config_data: 2440700000000000
profile_bits: 0000000000000000
block 1: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 2: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 3: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 4: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 5: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 6: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 7: 1=open 2=open 3=open 4=open 5=open, data=ffffff
finally full backup first
and make sx4 operation after that write pm 1-309 only
good luck
Old 12-02-2010, 08:54   #9 (permalink)
Member: 1393246
Thanks Meter: 22
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Scanning local SX4 Card ...
No SX4 Card found.
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.4
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 197.0.123.42
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Retrying ...
Retrying ...
Authenticating using [MX] security server ...
Old 12-02-2010, 09:05   #10 (permalink)
Member: 570626
Sonork: 100.1579059
Thanks Meter: 129
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
No SX4 Card found.
Retrying ...
Retrying ...
write full pm with PPM Auth
your problem will be solve 100%
WBR
shimul.
Old 12-02-2010, 09:12   #11 (permalink)
pawans's Avatar
Member: 346345
Sonork: jhon18
Thanks Meter: 56
mates u can auxiliiary pm 1-309..
Old 12-02-2010, 09:14   #12 (permalink)
Member: 1393246
Thanks Meter: 22
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0BB0000666B90158C7F96680BC0708DC38C49582
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6
TransmissionMode: DDR&TX2
Original Imei: 35683602129746
Original Product code: 0569931
Bluetooth ID: 0023B4B9CED0
WLAN ID: 0023B4C91110
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
No SX4 Card found.
Retrying ...
Retrying ...
SUPERDONGLE authorized !
Updating RFBB data ...
Writing section 1...
Writing section 309...
Done.
but same probleme contact realter
Old 12-02-2010, 09:39   #13 (permalink)
Member: 495352
Sonork: 100.1589707
Thanks Meter: 70
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
No SX4 Card found.
Retrying ...
Retrying ...
Done.
change another good pm
Old 12-02-2010, 09:57   #14 (permalink)
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 2,563
The server is busy! try later!!
Old 12-02-2010, 12:40   #15 (permalink)
Member deceased !!
R@SEL.NET's Avatar
Member: 670820
Sonork: 100.1583728
Thanks Meter: 1,348
post selftest log.......
The Following User Says Thank You to [email protected] For This Useful Post:
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.33808 seconds with 9 queries
