Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 12-09-2011, 16:02   #46 (permalink)
Member: 1359325
Sonork: 470928
Thanks Meter: 9
thanks ok sir
yes! we have this solution
1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl)
2. erase old pm ( go > pm tab > erase )
3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this)
4. Erase pm again (go > pm tab > erase )
5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei)
6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309)
7. erase pm again
8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert)
9. give full factory reset
100% okkkkkkkkkkkkkkkkkkkkkkkkkkkkk
Old 12-09-2011, 17:32   #47 (permalink)
Member: 1566017
Sonork: rerer
thank you for information
Old 12-09-2011, 17:40   #48 (permalink)
Member: 1566017
Sonork: rerer
Old 12-11-2011, 22:03   #49 (permalink)
sdr
sdr's Avatar
Member: 25136
Sonork: 1591036
Thanks Meter: 54
Thank's but not work for me !
Phone type: RM-337 (Nokia 6300i)
SW version: V 05.60 10-12-08 RM-337 (c) Nokia
Imei plain: 35483002-------6
Product code: 0555967
Battery voltage: 4834 mV, current: 67 mA
Language Pack:
- not available.
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SECURITY_TEST failed!
Imei net: 354830020402626
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 12-12-2011, 17:03   #50 (permalink)
Member: 314589
Thanks Meter: 3
old solution yar how many times this forum pls do not another solution
Old 01-19-2012, 15:21   #51 (permalink)
akashrana_sky's Avatar
Member: 1220933
Sonork: 100.1590184
Thanks Meter: 471
i can't give u thanks
because this is not your original post!
why copy past other post!
this is original post
http://forum.gsmhosting.com/vbb/f550...7/#post6034220
Old 01-19-2012, 15:35   #52 (permalink)
Member: 1220933
Sonork: 100.1590184
Thanks Meter: 471
MR>>>>>
sandhu36
For a good solution just need hard work.
why copy past other post?
it's is very shameful!
never will do this!
original link
(never copy past other post remember it)
Old 02-04-2012, 09:02   #53 (permalink)
Member: 1220933
Sonork: 100.1590184
Thanks Meter: 471
original post
Originally Posted by akashrana_sky View Post
Many people posted in this forum about security test failed !
we know that_______
when come security test failed ______
solution_____
1. super sd auth or pmm auth __than write good or modified pm ( must need pm 1 & 309)
or, 2. sd repair ___ super sd auth or pmm auth ____ than write good or modified pm ( must need pm 1 & 309)
My question ______
when we not success by up system
than what can we do for repair security test failed?
yes! we have this solution______
7. erase pm again
your phone must come back from security test failed
it is 100% tasted by me.
Don't forget to press thanks button !
original post
that i posted many times ago
Old 02-17-2012, 02:43   #54 (permalink)
Member: 374419
Thanks Meter: 61
This metode it`s not work with Nokia 5530 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
Need server option: PMM Auth.
MXKEY [FT SCR2000 0], SN: C08*****
Using device: HTI, FW ver: 00.50, SN: 000******
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 09600105F17E00520D9EFD8D99383AE1AA32169C
ASIC MODE ID: 00
ROM ID: 4B9B75103E691FF8
 SecondaryBoot: RAPIDOv11_2nd.fg [BB5]  version: 11.34.0 revision: 2.0 size: 0x3B80
 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000  - 0000 0000  type: RAM, asic:CMT
Storage1: FFFF 0000  - 0000 0000  type: MMC, asic:CMT
Storage2: 0020 0040  - 0000 0031 [ST  NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001  - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040  - 0000 0031 [ST  NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5]  version: 11.34.0 revision: 2.0 size: 0x8FE30
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF
Original Imei: 35802203******6
Original Product code: 0589309
Bluetooth ID: 9C1874D69D70
SIMLOCK PA identifier:
 [0] PA_SL3
Phone type: RM-504 (Nokia 5530 XpressMusic)
SW version: V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia
Imei plain: 358022031*****-6
Battery voltage: 4736 mV, current: 198 mA
ApeCoreSw: V 40.0.003
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 35802203******6
Counter: 0/3, 0/10
MX Box, this bad SW products.
Old 02-26-2012, 19:42   #55 (permalink)
beo_tech's Avatar
Member: 222999
Thanks Meter: 75
not work for me too
log:
SW version: V ICPR72_10w25.3 11-10-10 RM-504 (c) Nokia
Imei plain: 35936803408306-1
Product code: 0573150
Battery voltage: 4125 mV, current: 143 mA
ApeCoreSw: V 32.0.007
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
Old 02-27-2012, 13:30   #56 (permalink)
DOSTI's Avatar
Member: 446289
Thanks Meter: 106
Originally Posted by Dipendra Pathak View Post
There are 1000 of sets are in Nokia Care Center who have problem of SECURITY TEST FAILED. OK, show me the proof to repair 5130c's security test failed.
ya dear u r right that solustion not work with sl3 phoneeeeeeeeeeee
Old 02-27-2012, 16:51   #57 (permalink)
Member: 1727203
good post
thanks
Old 03-05-2012, 08:44   #58 (permalink)
Member: 440255
Thanks Meter: 6
very nice dear keep it up and *** bless u
Old 06-29-2012, 16:18   #59 (permalink)
Member: 1341683
Sonork: 1431
Thanks Meter: 33
Thumbs up 3110 security test fail
Originally Posted by sandhu36 View Post
all security test failed 100% solution!
we know that
solution
1. super sd auth or pmm auth than write good or modified pm ( must need pm 1 & 309)
or, 2. sd repair super sd auth or pmm auth than write good or modified pm ( must need pm 1 & 309)
7. erase pm again
i've nokia 3110..
after flash set go on contact service..
security test fail..
pls help me
Old 06-29-2012, 17:32   #60 (permalink)
manule's Avatar
Member: 786607
Thanks Meter: 66
not work 5530 still sam esecurity failed
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Page generated in 0.26013 seconds with 10 queries
