Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 07-25-2010, 07:04   #16 (permalink)
shihabkv's Avatar
Member: 383297
Sonork: 100.1591997
Thanks Meter: 54
thannksssssssssssssssssssss
The Following User Says Thank You to shihabkv For This Useful Post:
Old 07-25-2010, 07:30   #17 (permalink)
ali 4800's Avatar
Member: 1172108
Thanks Meter: 301
''':::Nice work keep it up::'''
The Following User Says Thank You to ali 4800 For This Useful Post:
Old 07-25-2010, 12:43   #18 (permalink)
mobilecomplete's Avatar
Member: 1300284
Thanks Meter: 41
I have a set 3110 he is securty test failed i done my best and try your solution but no secuss set condeation is contact service please help
Old 07-25-2010, 15:47   #19 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 403
some time all is valid but still contact service now what to do please explain............
Old 07-25-2010, 16:02   #20 (permalink)
Rizwan ch08's Avatar
Member: 637860
Sonork: 100.1605309
Thanks Meter: 927
thanks brother ..........................very nice info
The Following User Says Thank You to Rizwan ch08 For This Useful Post:
Old 07-25-2010, 18:25   #21 (permalink)
uttam4u2002's Avatar
Member: 523972
Sonork: 100.1596548
Thanks Meter: 1,168
Brother, when all things r valid and u r phone show contact service. check in hardware, Its not software problem.
B.R.,
B.Uttam
Old 07-26-2010, 04:49   #22 (permalink)
thinh_mobile's Avatar
Member: 189487
Thanks Meter: 28
Can you give me the pictures illustrate? thanks a lot!
Old 07-26-2010, 12:28   #23 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 403
B.R.,
B.Uttam
which part to check for contact service
Old 08-18-2010, 09:14   #24 (permalink)
Member: 713472
Thanks Meter: 2
very very very good work
Old 09-07-2010, 14:27   #25 (permalink)
sandhu36's Avatar
Member: 387696
Thanks Meter: 161
u
post ful log
Old 09-07-2010, 14:47   #26 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,428
2nd or 3rd option of security test fail solution
IF ALL SOLUTION NOT WORK THEN
1. Firest Backup Just Npc Rpl In Sl2 And Full Rpl Backup In Sl3 Most Importanat Simlock Data (save simlock rpl extra for sl3)
2. Second Erase set with erase file then flash with any version after flash write npc data rpl with clone rpl ccc and hwc data (by model)
After write repair superdongle key and simlock data in sl 2 write full pm with SX4 server.
and Sl3 also erase and write flash after flash write npc data rpl with ccc and hwc not full then simlock data rpl after write rpl repair SD then write full pm with SX4 Server.
and 3rd solution for 3110c all thing try but security test fail not ok then just do that backup npc data rpl then write another set rpl dont worry about anything when writing ok then check ur imei crrupt SD crrupt and simlock data crrupt but security test pass.after this condtion just write npc data rpl then repair sd then simlock then write full pm with sx4 server ur set ok.
(some time 3110c writing wrong rpl show error but ur work is done or some time after write wrong rpl ur imei is not currpt but ur sd and simlock data crrupt and security test pass)
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post:
Old 09-07-2010, 17:03   #27 (permalink)
Member: 839882
Thanks Meter: 29
thanks for sharing..................
Old 09-21-2010, 08:53   #28 (permalink)
Member: 789503
Thanks Meter: 5
thanksssssssssss
thanks budy its nice job.
Old 09-21-2010, 09:00   #29 (permalink)
Member: 658765
Thanks Meter: 12
very very important information
Old 09-30-2010, 06:03   #30 (permalink)
Member: 594881
Thanks Meter: 77
thanks for this method....just repaired 1 3110c with this.....
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 11:35
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-12-2012 12:26
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 04:52
Page generated in 0.39360 seconds with 8 queries
